StarTech.com USB 3.1 Adapter Cable w/ USB-C
Quicklinx: BL71WS00 Mfr#: USB31CSAT3CB
£17.63 ex VAT
£21.15 inc VAT
Get ultra-fast access to data by connecting a 2.5" SATA SSD/HDD to your laptop's USB-C port. Take advantage of the USB-C port on the latest MacBook, Chromebook Pixel or other laptop to get quick external drive access. This cable-style adapter lets you use the USB Type-C port to connect your laptop directly to a 2.5" solid-state or hard drive and access it through ultra-fast USB 3.1 Gen. 2 (10 Gbps). It's fast and easy to connect to your SATA drives, with no additional accessories required.
Use this cable-style adapter, wherever you go, to access valuable data quickly - it's USB powered so there's no external power required. It features a compact, lightweight design that tucks easily into a laptop bag or carrying case.
With the adapter cable, you can quickly swap hard drives without having to install your drives into an enclosure. You can copy or retrieve data from a 2.5" SSD or HDD quickly. It gives you easy drive access for data migration, drive cloning and data backup applications, with the fast performance of USB 3.1 Gen 2.
The integrated, easy-to-use USB Type-C connector is small and reversible, which makes for easier insertions. You can connect the plug with either side facing up, which means less risk of damaging your ports, and less frustration.
USB 3.1 Gen 2 gives you greater bandwidth and speed with file transfer rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
  • Efficient data transfer
    With a data transfer rate of 6 Gbit/s, this adapter facilitates quick file transfers between your SATA drives and USB-C devices.
  • Broad compatibility
    This adapter is compatible with both 2.5'' and 3.5'' SATA drives, allowing a versatile solution for different storage needs.
  • Simple setup
    The integrated USB cable design eliminates the hassle of multiple cables, making it easy to connect and disconnect as needed.
  • High-speed interface
    Supported by USB 3.1 (Gen 2), this adapter ensures optimal performance for accessing and transferring data.
  • Mac compatibility
    Designed for Mac users, this adapter ensures seamless connectivity without additional drivers.
StarTech.com USB C to SATA Adapter - External Hard Drive Connector for 2.5'' SATA Drives - SATA SSD / HDD to USB C Cable (USB31CSAT3CB) - storage controller - SATA 6Gb/s - USB 3.1 (Gen 2)
Storage controller - external
Bus Type
USB 3.1 (Gen 2)
Hard Drive Form Factor Compatibility
2.5", 3.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
4.3 cm x 50.8 cm x 5 mm
29.2 g
2.5", 3.5"
Host Bus
USB 3.1 (Gen 2)
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 24 pin USB-C
1 x USB cable - integrated
4.3 cm
50.8 cm
5 mm
29.2 g
BL71 StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.33
BL71 StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.36
BL71 StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £8.33
BL71 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.57
BL71 StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.13
BL71 StarTech.com USB 3.1 Adapter Cable w/ USB-C In Stock £17.63
BL71 StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.59
BL71 StarTech.com CFast Card Reader - USB 3.0 In Stock £22.38
BL71 StarTech.com CFast Card Reader - USB-C In Stock £28.39
BL71 StarTech.com USB 3.0 to eSATA HDD/SSD/ODD Adapter Cable – USB-C In Stock £24.82
