Brand
StarTech.com USB 3.1 / eSATA 1-bay Dock
Quicklinx: CPBMWS00 Mfr#: SDOCKU313E
Type: HDD docking station
HD Size: 2.5, 3.5
Power Supply: Power adapter
12 In Stock
£56.18 ex VAT
£67.41 inc VAT
Dock and access your SATA SSD/HDD through high-performance USB 3.1 (10Gbps) or eSATA. Connect and access any 2.5" or 3.5" SATA hard drive or SSD using this single-drive docking station, over a USB 3.1 Gen 2 (up to 10Gbps) or eSATA connection.
Ideal for IT professionals, the docking station lets you access a SATA solid-state drive or hard drive quickly, for drive imaging, data recovery, and backups.
You can connect through either USB 3.1 Gen 2 or eSATA, and take advantage of the high performance of the latest SSDs and HDDs.
The dock's vertical drive insertion makes it easy to dock and swap drives from your desktop computer or laptop. You simply insert your SSD or HDD into the drive slot at the top of the docking station, with no tools or trays required. The HDD ejection button allows fast and simple drive removal.
The single-bay docking station comes with a USB Type-A to Type-C cable, for connecting to newer USB-C enabled devices. It also comes with a USB Type-A to Type-B cable, providing backward compatibility with your existing USB 3.0, 2.0 and 1.x devices. An eSATA cable is also included with the dock.
The docking station is also UASP compatible, for enhanced performance.
StarTech.com USB 3.1/eSATA Drive Docking Station for 2.5"/3.5" SATA Drives - External USB 3.1 (10Gbps) Hard Drive Dock w/ UASP (SDOCKU313E) - HDD docking station - SATA 6Gb/s - eSATA, USB 3.1 (Gen 2)
HDD docking station - external
Bays
1
Bus Type
Expansion Bays
1 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
1
Product Material
Plastic
AC 120/230 V
9.3 cm x 14.5 cm x 6.52 cm
500 g
Bays
1
2.5", 3.5"
Host Bus
Product Material
Plastic
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
1
ASMedia ASM1351
Bays
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 9 pin USB Type B , 1 x eSATA - 7 pin external Serial ATA
1 x USB cable - external - 1 m , 1 x USB-C cable - external - 1 m , 1 x eSATA cable - external - 1 m
Tested with up to 6TB 7200 RPM hard drives, UASP transfer protocol
FCC, RoHS
Power adapter
AC 120/230 V
9.3 cm
14.5 cm
6.52 cm
500 g
5 °C
35 °C
20 - 80%
CPBM StarTech.com 3 ft Shielded External eSATA Cable M/M In Stock £8.88
CPBM StarTech.com 2 Port SATA to eSATA Slot Plate Bracket In Stock £8.16
CPBM StarTech.com 6 ft Shielded External eSATA Cable M/M In Stock £10.50
CPBM StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.36
CPBM StarTech.com 1ft Low Profile SATA to eSATA Plate Adapter In Stock £6.36
CPBM StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £20.69
CPBM StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.60
CPBM StarTech.com 1 Port SATA to eSATA Slot Plate Bracket In Stock £6.50
CPBM StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £8.86
CPBM StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £18.54
CPBM StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £19.47
CPBM StarTech.com 18in 1 Port SATA to eSATA Plate Adapter In Stock £8.04
CPBM StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £29.35
CPBM StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £53.65
CPBM StarTech.com USB 3.1 Tool-free Enclosure In Stock £25.00
CPBM StarTech.com USB 3.1 Gen 2 Dual-bay Dock In Stock £86.95
CPBM StarTech.com USB 3.1 Gen 2 Adapter Cable In Stock £14.66
CPBM StarTech.com USB 3.1 Gen 2 Enclosure In Stock £46.64
CPBM StarTech.com USB 3.1 / eSATA 1-bay Dock In Stock £56.18
CPBM StarTech.com 4 Bay SSD/HDD Docking Station In Stock £144.99
HD Size: 2.5
HD Size: 3.5
