Add a secondary VGA display to your USB 3.0 enabled PC, and install the drivers without a CD or Internet connection. This USB 3.0 to VGA video adapter works as an external video card, enabling the USB port on your computer to output video to a VGA display at high resolution. The adapter also features on-board driver installation, which means the adapter will work when you connect it, even without a software disc or Internet connection. For the ultimate in hassle-free installation, this USB video adapter features on-board drivers which prompts for installation as soon as you connect the adapter to your Ultrabook or laptop computer. This means you can maximize portability by never requiring an installation disc or Internet connection to install the device.
Adding a second or third display to your computer can vastly increase your productivity by giving the freedom to access more applications at the same time. This video adapter is intended to support all of your business applications including web browsing. You can also leave your system video card available for more demanding applications such as gaming or CAD design, while you use the USB monitor for reference material. Using the high-bandwidth USB 3.0 interface, this adapter enables smoother scrolling through documents, higher refresh rates and an overall enhanced performance over USB 2.0. The adapter is optimized for use with USB 3.0, but for added compatibility this adapter is also backward compatible with USB 2.0 computer systems.
High Resolution Support
The adapter provides maximum output resolution of 1920 x 1200, ensuring crisp and clear visuals for presentations and other applications. -
Broad Compatibility
Designed to work seamlessly with both USB 2.0 and USB 3.0 standards, allowing versatile connections with various devices. -
Easy Connectivity
Equipped with a 9-pin USB Type-A male connector and a 15-pin HD D-Sub female connector, enabling straightforward Plug-and-Play setup.
- StarTech.com USB 3.0 to VGA Display Adapter 1920x1200, On-Board Driver Installation, Video Converter with External Graphics Card - Windows (USB32VGAV) - USB / VGA adapter - USB Type A to HD-15 (VGA) - 19.5 m
- USB / VGA adapter
- 1920 x 1200 (WUXGA) support
- Length
- 19.5 m
- Connector
- 9 pin USB Type A - male (input)
- Connector (Second End)
- 15 pin HD D-Sub (HD-15) - female
- USB / USB 2.0 / USB 3.0
- 2-year warranty
- Designed For
- P/N: MXT101MM
- USB / VGA adapter
- Length
- 19.5 m
- 2.5 cm
- 1.2 cm
- 9.3 g
- Connector
- USB / USB 2.0 / USB 3.0, FCC, RoHS
- Shipping Width
- 14.3 cm
- Shipping Depth
- 17.2 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 92 g
- 2-year warranty
- Designed For
- P/N: MXT101MM
StarTech.com USB to VGA External Video Card Multi Monitor Adapter – 1920x1200 | In Stock | £12.18 |
StarTech.com USB 3.0 to VGA External Video Card Multi Monitor Adapter for Mac and PC | In Stock | £24.96 |
StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £19.75 |
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 | In Stock | £57.08 |
StarTech.com USB 3.0 VGA Video Adapter | In Stock | £17.38 |
StarTech.com USB 3.0 to HDMI VGA Adapter - 4K 30 - External Video & Graph | In Stock | £63.24 |
