Connect your USB Type-A device to a USB Type-C laptop, tablet or other device. This USB-C to USB-A adapter lets you connect standard USB 3.0 and USB 2.0 devices to your USB-C equipped phone, tablet or computer. Simply plug the adapter into the USB Type-C port to turn it into a USB Type-A port, and you're ready to connect your older devices. The adapter is compatible with USB 3.0 enabled computers, such as the Dell Latitude 11 5000 2-in-1, and more.
USB 3.0 is also known as USB 3.1 Gen 1 (5Gbps).
Efficient data transfer
This adapter supports USB 3.1 standards, allowing data transfer rates of up to 5 Gbps, which enhances the speed at which data can be moved between devices. -
Durable construction
Featuring nickel plated connectors, this adapter is designed to resist corrosion and wear, ensuring long-lasting performance with frequent use.
- StarTech.com USB-C to USB Adapter - USB-C to USB-A - USB 3.1 Gen 1 - 5Gbps - USB C Adapter - USB Type C (USB31CAADG) - USB-C adapter - 24 pin USB-C to USB Type A
- USB-C adapter
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 9 pin USB Type A - female
- USB 3.1
- Black
- 2-year warranty
- Designed For
- P/N: HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, PEXUSB311AC3
- USB-C adapter
- Plated Connector
- Nickel
- Black
- 8.4 g
- Connector
- USB 3.1, RoHS
- 2-year warranty
- Designed For
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £10.07 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £10.18 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £11.84 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £14.29 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £9.09 |
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £10.11 |
StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 | In Stock | £9.47 |
