StarTech.com USB 3.0 USB-C to USB-A Adapter
Quicklinx: C9WTWS00 Mfr#: USB31CAADG
£8.23 ex VAT
£9.87 inc VAT
Connect your USB Type-A device to a USB Type-C laptop, tablet or other device. This USB-C to USB-A adapter lets you connect standard USB 3.0 and USB 2.0 devices to your USB-C equipped phone, tablet or computer. Simply plug the adapter into the USB Type-C port to turn it into a USB Type-A port, and you're ready to connect your older devices. The adapter is compatible with USB 3.0 enabled computers, such as the Dell Latitude 11 5000 2-in-1, and more.
USB 3.0 is also known as USB 3.1 Gen 1 (5Gbps).
StarTech.com USB-C to USB Adapter - USB-C to USB-A - USB 3.1 Gen 1 - 5Gbps - USB C Adapter - USB Type C (USB31CAADG) - USB-C adapter - 24 pin USB-C to USB Type A
USB-C adapter
Connector
24 pin USB-C - male
Connector (Second End)
9 pin USB Type A - female
USB 3.1
P/N: HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, PEXUSB311AC3
USB-C adapter
Plated Connector
Nickel
8.4 g
Connector
24 pin USB-C - male
USB 3.1, RoHS
C9WT StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £10.72
C9WT StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.82
C9WT StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £11.37
C9WT StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £14.11
C9WT StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £9.21
C9WT StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £16.47
C9WT StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £9.61
