StarTech.com USB 3.0 Type-C to 2.5 Gigabit Ethernet Adapter
Quicklinx: FHK4WS00 Mfr#: US2GC30
Wired / Wireless: Wired
Protocol: Fast Ethernet, Gigabit Ethernet, Ethernet, 2.5 Gigabit Ethernet
Form Factor: External
Compatibility: [N/A]
Type: Network adapter
13 In Stock
£32.55 ex VAT
£39.06 inc VAT
Add 2.5 GbE network access to your laptop, using an available USB-C port. This USB 3.0 Type-C to Gigabit network adapter gives you wired Ethernet network access.
Ideal for office or home use, the network adapter supports full 2.5 Gigabit bandwidth by harnessing the performance of USB 3.0. You can quickly access very large files over a 2.5 Gigabit network, saving valuable time every day.
Get up and running quickly. Simply plug this USB-C to Ethernet adapter into the USB port on your laptop and connect to your network. The network adapter Realtek RTL8156 chipset provides native driver support for Mac OS and Linux. Any Windows operating systems without the driver will be automatically prompted to download the software directly from the adapter, ensuring a quick installation with no Internet access required.
Compact and portable, this USB Gigabit network adapter is the ideal desktop network adapter or laptop accessory. You don't have to carry a power adapter with you to use it, because it's powered directly from the host USB port.
  • Powerful 2.5 Gigabit Network Connections
  • Native Driver Support Makes Installation Easy
    Get up and running quickly. Simply plug this USB-C to Ethernet adapter into the USB port on your laptop and connect to your network. The network adapter Realtek RTL8156BG chipset provides native driver support for Mac OS and Linux. Any Windows operating systems without the driver will be automatically prompted to download the software directly from the adapter, ensuring a quick installation with no Internet access required.
  • Compact & Lightweight for Perfect Portability
  • The Choice of IT Pros Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. The US2GC30 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 2.5GbE USB C to Ethernet Adapter NBASE-T NIC, USB 3.0 Type C 2.5/1 Gigabit/100 Mbps Multi Speed Network/USB 3.1 Laptop to RJ45/LAN Thunderbolt 3 Compatible/MacBook Pro Surface - Type-C to Ethernet - network adapter - USB-C - 10M/100M/1G/2.5 Gigabit Ethernet x 1 + USB 3.0
Network adapter
External
Interface (Bus) Type
USB-C
Ports
2.7 cm 8 cm
Length
1.6 cm
39.7 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-BX
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
Data Transfer Rate
2.5 Gbps
Jumbo frame size: 16000
Realtek Semiconductor RTL8156
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3bz
Black, space grey
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Linux Kernel 2.4.20 or later (LTS versions only), Apple macOS 13.0
Network adapter
External
USB-C
Ports
Wired
Cabling Type
Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
2.5 Gbps
Status Indicators
Link/activity
Full duplex capability, auto-uplink (auto MDI/MDI-X), Jumbo Frames support
Processor / Memory
1 x 1/2.5GBase-T - RJ-45 - receptacle , 1 x USB 3.0 - 24 pin USB-C - plug
1 x SuperSpeed USB-C cable (integrated)
FCC, RoHS, WEEE, REACH
Black, space grey
2.7 cm
8 cm
Length
1.6 cm
39.7 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
100 g
70 °C
5 - 90% (non-condensing)
FHK4 StarTech.com USB-C to Ethernet Adapter In Stock £14.06
FHK4 StarTech.com USB Type-C Ethernet Adapter In Stock £21.09
Protocol: Gigabit Ethernet
Protocol: Ethernet
Protocol: 2.5 Gigabit Ethernet
