USB LAN Adapter IEEE 802.3bz 2.5 Gbps Mac Windows Linux. Add 2.5 GbE network access to your laptop, using the USB-A port on your laptop. This USB 3.0 Type-A to Gigabit network adapter gives you wired Ethernet network access.
Powerful 2.5 Gigabit Network Connections
Ideal for office or home use, the network adapter supports full 2.5 Gigabit bandwidth by harnessing the performance of USB 3.0. You can quickly access very large files over a 2.5 Gigabit network, saving valuable time every day.
Native Driver Support Makes Installation Easy
Get up and running quickly. Simply plug this USB-A to Ethernet adapter into the USB port on your laptop and connect to your network. The network adapter Realtek RTL8156 chipset provides native driver support for Mac OS and Linux. Any Windows operating systems without the driver will be automatically prompted to download the software directly from the adapter, ensuring a quick installation with no Internet access required.
Compact & Lightweight for Perfect Portability
Compact and portable, this USB Gigabit network adapter is the ideal desktop network adapter or laptop accessory. You don't have to carry a power adapter with you to use it, because it's powered directly from the host USB port.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
The US2GA30 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Ideal for office or home use, the network adapter supports full 2.5 Gigabit bandwidth by harnessing the performance of USB 3.0. You can quickly access very large files over a 2.5 Gigabit network, saving valuable time every day. -
Get up and running quickly. Simply plug this USB-A to Ethernet adapter into the USB port on your laptop and connect to your network. The network adapter Realtek RTL8156 chipset provides native driver support for Mac OS and Linux. Any Windows operating systems without the driver will be automatically prompted to download the software directly from the adapter, ensuring a quick installation with no Internet access required. -
Compact and portable, this USB Gigabit network adapter is the ideal desktop network adapter or laptop accessory. You don't have to carry a power adapter with you to use it, because it's powered directly from the host USB port. -
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. The US2GA30 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com 2.5GbE USB A to Ethernet Adapter, NBASE-T NIC, USB 3.0 Type A 2.5 GbE /1 GbE Multi Speed Gigabit Network, USB 3.1 Laptop to RJ45/LAN, Lenovo X1 Carbon, HP EliteBook/ ZBook - Type-A to Ethernet (US2GA30) - network adapter - USB 3.0 - 10M/100M/1G/2.5 Gigabit Ethernet x 1
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- 3 cm x 1.6 cm
- 39.7 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
- Data Transfer Rate
- 2.5 Gbps
- Capacity
- Jumbo frame size: 16000
- Processor
- Realtek Semiconductor RTL8156
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3bz, USB 3.1 Gen 1
- Black, space grey
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Linux Kernel 2.4.20 or later (LTS versions only), Apple macOS 13.0, Microsoft Windows 7 / 8.1 / 10 / 11
- 2-year warranty
- Network adapter
- Form Factor
- External
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
- 2.5 Gbps
- Capacity
- Status Indicators
- Link/speed
- Auto-uplink (auto MDI/MDI-X), full duplex mode, USB powered, VLAN Tagging, promiscuous mode
Processor / Memory
- Processor
- 1 x 2.5Gb Ethernet - RJ-45 - female
- Cables Included
- 1 x USB cable (integrated) - 15 cm
- MTBF
- 10,000 hours
- FCC, RoHS, REACH
- Black, space grey
- OS Required
- 3 cm
- 1.6 cm
- 39.7 g
- Shipping Width
- 2.7 cm
- Shipping Depth
- 1.6 cm
- Shipping Height
- 8 cm
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 5 - 90% (non-condensing)
StarTech.com USB Type-C Ethernet Adapter | In Stock | £21.09 |
