StarTech.com USB 3.0 Trayless External 3.5" SATA III HDD Enclosure w/ UASP for SATA 6 Gbps – Black
Quicklinx: 93JRWS00 Mfr#: S3510BMU33T
  • Windows 8 (32/64 bits)
Easily connect and hot swap 3.5in SATA hard drives, with an external UASP-supported USB 3.0 black enclosure. The S3510BMU33T Removable Hard Drive Enclosure lets you to connect a 3.5" SATA hard drive through an available USB 3.0 port, with a tray-less design that makes hot-swapping easy.
For universal compatibility, you can connect the enclosure through USB 3.0, with support for UASP. When connected to a UASP compatible host port, the enclosure is capable of performance up to 70% faster than conventional USB 3.0, making it easy to take advantage of the full speed potential of your SATA III hard drives.
The HDD enclosure offers a versatile solution for increasing the storage/backup capabilities of your computer, with support for large capacity hard drives, and the ability to easily hot-swap between drives. Plus, to maximize both durability and reliability, the enclosure features high-quality aluminum construction.
StarTech.com USB 3.0 Trayless External 3.5" SATA HDD Enclosure w/ UASP - storage enclosure - SATA 6Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Expansion Bays
1 x internal - 3.5"
Hard Drive Form Factor Compatibility
3.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
1
Product Material
Aluminium
AC 100/230 V
Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
14.5 cm x 20.6 cm x 3.8 cm
930 g
P/N: HB30C3A1GE, HB30C3A1GEA, HB30C3AGEPD
3.5"
Host Bus
USB 3.0
Product Material
Aluminium
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
1
ASMedia ASM1051E
Bays
1 x internal - 3.5"
1 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 9 pin USB Type B
1 x USB cable - external
LED indicator, tested with up to 4TB 7200 RPM hard drives
Plug and Play, FCC, RoHS
Power adapter
AC 100/230 V
14.5 cm
20.6 cm
3.8 cm
930 g
5 °C
35 °C
20 - 80%
93JR StarTech.com 1m USB 3 Cable Right Angle BK In Stock £7.23
93JR StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £9.84
93JR StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £7.61
