Easily connect and hot swap 3.5in SATA hard drives, with an external UASP-supported USB 3.0 white enclosure.
The S3510WMU33T Removable Hard Drive Enclosure lets you to connect a 3.5" SATA hard drive through an available USB 3.0 port, with a tray-less design that makes hot-swapping easy.
For universal compatibility, you can connect the enclosure through USB 3.0, with support for UASP. When connected to a UASP compatible host port, the enclosure is capable of performance up to 70% faster than conventional USB 3.0, making it easy to take advantage of the full speed potential of your SATA III hard drives.
The HDD enclosure offers a versatile solution for increasing the storage/backup capabilities of your computer, with support for large capacity hard drives, and the ability to easily hot-swap between drives. Plus, to maximize both durability and reliability, the enclosure features high-quality aluminum construction.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
- StarTech.com USB 3.0 Trayless External 3.5" SATA HDD Enclosure w/ UASP - storage enclosure - SATA 6Gb/s - USB 3.0
- Storage enclosure - external
- Bus Type
- USB 3.0
- White
- Expansion Bays
- 1 x internal - 3.5"
- Hard Drive Form Factor Compatibility
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Max Storage Devices Qty
- 1
- Product Material
- Aluminium
- Power
- AC 100/230 V
- System Requirements
- Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
- 14.5 cm x 20.6 cm x 3.8 cm
- 930 g
- 2-year warranty
- 3.5"
- Host Bus
- USB 3.0
- Product Material
- Aluminium
- White
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- 1
- Processor
- ASMedia ASM1051E
- Bays
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.0 - 9 pin USB Type B
- Cables Included
- 1 x USB cable - external
- LED indicator, tested with up to 4TB 7200 RPM hard drives
- Plug and Play, FCC, RoHS
- Power adapter
- Voltage Required
- AC 100/230 V
- OS Required
- Limited warranty - 2 years
- 14.5 cm
- 20.6 cm
- 3.8 cm
- 930 g
- 5 °C
- 35 °C
- 20 - 80%
StarTech.com 1m USB 3 Cable Right Angle BK | In Stock | £6.63 |
StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £11.11 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £8.94 |
