Connect a VGA-equipped display through USB 3.0, while keeping the USB 3.0 port available. The USB32VGAEH USB 3.0 to VGA Adapter turns a USB 3.0 port into a VGA output port with 1920x1200 (WUXGA) video support. The adapter features a built-in 1-Port USB 3.0 hub, which offers a connection port in place of the USB port used for connecting the VGA adapter - an ideal workaround for Ultrabook or laptop users where only a limited number of USB ports are available.
Functioning as an external graphics card, this USB to VGA adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your VGA display / projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
- StarTech.com USB 3.0 to VGA Adapter with 1 Port USB Hub - 1920x1200 - External Video & Graphics Card - Dual Monitor Display Adapter - Supports Windows (USB32VGAEH) - external video adapter - T5-302 - 16 MB - black
- External video adapter
- Bus Type
- SuperSpeed USB 3.0
- Graphics Engine
- MCT Trigger 5 T5-302
- Memory
- 16 MB DDR2
- Max Resolution
- 1920 x 1200
- VGA , USB 3.0
- 4.9 cm x 8.5 cm x 1.7 cm
- Enclosure Colour
- Black
- 2-year warranty
- Designed For
- P/N: MXT101MM
- Bus Type
- Graphics Engine
- Max Resolution
- 1920 x 1200
- VGA , USB 3.0
- USB powered, USB Pass-Through
- Size
- 16 MB
- Technology
- DDR2 SDRAM
- OS Required
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
- Min Processor Type
- Intel Core i3 2.8 GHz
- Min RAM Size
- 2 GB
- Additional Requirements
- USB port
- Cables Included
- 1 x SuperSpeed USB cable - 16 cm
- Software Included
- Drivers & Utilities
- WHQL, FCC
- 4.9 cm
- 8.5 cm
- 1.7 cm
- 75 g
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 0 - 85% (non-condensing)
- Designed For
- P/N: MXT101MM
