Connect a 2.5in / 3.5in SATA or IDE Hard Drive through a USB 3.0 Port. The USB3SSATAIDE USB 3.0 to IDE/SATA Adapter Cable connects any standard 2.5in or 3.5in SATA or IDE hard drive to a computer through an available USB 3.0 Port (Backward compatible with USB 2.0). The adapter lets you connect a bare drive with no enclosure, saving time and hassle.
The USB 3.0 SATA/IDE Adapter lets you externally connect a bare drive with no drive enclosure or HDD dock required, and features LED indicators that allow you to easily monitor status and activity updates.
The adapter cable works with Windows, Linux, and Mac computers and does not require any software or driver installation - a true plug-and-play solution for adding cost-effective external storage, or overcoming incompatibility between all hard drives and USB enabled motherboards that may not be SATA or IDE-equipped.
The USB3SSATAIDE USB 3.0 to IDE/SATA Adapter Cable comes complete with universal adapter and power cords, providing the additional power required to connect 3.5-inch and larger capacity 2.5-inch hard drives.
- StarTech.com USB 3.0 to SATA IDE Adapter - 2.5in / 3.5in - External Hard Drive to USB Converter - Hard Drive Transfer Cable (USB3SSATAIDE) - storage controller - ATA / SATA - USB 3.0
- Storage controller - external
- Bus Type
- USB 3.0
- Black
- Interface
- ATA / SATA
- Data Transfer Rate
- 4.8 GBps
- Supported Devices
- Hard drive, solid state drive
- Max Storage Devices Qty
- 3
- Product Material
- Plastic
- System Requirements
- Apple MacOS 8.6 or later, Linux, Microsoft Windows 2000, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
- 21.5 cm x 15 cm x 5.2 cm
- 419 g
- 2-year warranty
- Designed For
- P/N: PEXUSB3S42V, PEXUSB3S44V
- Host Bus
- USB 3.0
- Product Material
- Plastic
- Black
Storage Controller
- Interface
- ATA / SATA
- 4.8 GBps
- Supported Devices
- 3
- 1 x ATA - 40 PIN IDC , 1 x ATA - 44 PIN IDC , 1 x SATA 3Gb/s - SATA
- Connections
- 1 x USB 3.0 - 9 pin USB Type A
- Included Accessories
- Power 15 pin SATA to 4 pin adapter, power supply
- Cables Included
- 1 x power 15 pin SATA to 4 pin adapter - external
- LED indicator
- FCC, RoHS
- OS Required
- Limited warranty - 2 years
- 21.5 cm
- 15 cm
- 5.2 cm
- 419 g
- 0 °C
- 50 °C
- 5 - 85%
- Designed For
StarTech.com 24" Serial ATA Cable | In Stock | £5.16 |
StarTech.com 18in SATA Serial ATA Cable | In Stock | £2.51 |
StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.70 |
StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable | In Stock | £5.36 |
StarTech.com 12in Latching SATA Cable | In Stock | £5.50 |
StarTech.com 18in Latching SATA Cable | In Stock | £3.89 |
StarTech.com 24in Latching SATA Cable | In Stock | £6.76 |
StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable | In Stock | £4.96 |
StarTech.com 6in SATA Serial ATA Cable | In Stock | £3.55 |
StarTech.com 12in SATA Serial ATA Cable | In Stock | £4.46 |
StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F | In Stock | £6.16 |
StarTech.com 12in SATA to Left Angle SATA Serial ATA Cable | In Stock | £4.82 |
StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable | In Stock | £3.92 |
StarTech.com 6in SATA to Right Angle SATA Serial ATA Cable | In Stock | £3.85 |
StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable | In Stock | £8.04 |
StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 Cable | In Stock | £23.03 |
StarTech.com USB 3.1 Adapter Cable w/ USB-C | In Stock | £16.51 |
StarTech.com USB 3.1 2.5/3.5" SATA Adapter | In Stock | £26.81 |
StarTech.com USB C to SATA Adapter Cable | In Stock | £34.51 |
StarTech.com 18in Right Angle SATA Cable | In Stock | £4.22 |
