StarTech.com USB 3.0 to SATA or IDE Hard Drive Adapter Converter
Quicklinx: 8TJFWS00 Mfr#: USB3SSATAIDE
  • Windows 8 (32/64 bits)
Connect a 2.5in / 3.5in SATA or IDE Hard Drive through a USB 3.0 Port. The USB3SSATAIDE USB 3.0 to IDE/SATA Adapter Cable connects any standard 2.5in or 3.5in SATA or IDE hard drive to a computer through an available USB 3.0 Port (Backward compatible with USB 2.0). The adapter lets you connect a bare drive with no enclosure, saving time and hassle.
The USB 3.0 SATA/IDE Adapter lets you externally connect a bare drive with no drive enclosure or HDD dock required, and features LED indicators that allow you to easily monitor status and activity updates.
The adapter cable works with Windows, Linux, and Mac computers and does not require any software or driver installation - a true plug-and-play solution for adding cost-effective external storage, or overcoming incompatibility between all hard drives and USB enabled motherboards that may not be SATA or IDE-equipped.
The USB3SSATAIDE USB 3.0 to IDE/SATA Adapter Cable comes complete with universal adapter and power cords, providing the additional power required to connect 3.5-inch and larger capacity 2.5-inch hard drives.
StarTech.com USB 3.0 to SATA IDE Adapter - 2.5in / 3.5in - External Hard Drive to USB Converter - Hard Drive Transfer Cable (USB3SSATAIDE) - storage controller - ATA / SATA - USB 3.0
Storage controller - external
Bus Type
USB 3.0
ATA / SATA
Data Transfer Rate
4.8 GBps
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
3
Product Material
Plastic
Apple MacOS 8.6 or later, Linux, Microsoft Windows 2000, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
21.5 cm x 15 cm x 5.2 cm
419 g
P/N: PEXUSB3S42V, PEXUSB3S44V
Host Bus
USB 3.0
Product Material
Plastic
Storage Controller
ATA / SATA
Data Transfer Rate
4.8 GBps
Supported Devices
3
1 x ATA - 40 PIN IDC , 1 x ATA - 44 PIN IDC , 1 x SATA 3Gb/s - SATA
1 x USB 3.0 - 9 pin USB Type A
Power 15 pin SATA to 4 pin adapter, power supply
1 x power 15 pin SATA to 4 pin adapter - external
LED indicator
FCC, RoHS
21.5 cm
15 cm
5.2 cm
419 g
50 °C
5 - 85%
8TJF StarTech.com 24" Serial ATA Cable In Stock £5.28
8TJF StarTech.com 18in SATA Serial ATA Cable In Stock £2.50
8TJF StarTech.com 36in SATA Serial ATA Cable In Stock £5.70
8TJF StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.50
8TJF StarTech.com 12in Latching SATA Cable In Stock £6.16
8TJF StarTech.com 18in Latching SATA Cable In Stock £4.24
8TJF StarTech.com 24in Latching SATA Cable In Stock £6.84
8TJF StarTech.com 6in SATA Serial ATA Cable In Stock £3.61
8TJF StarTech.com 12in SATA Serial ATA Cable In Stock £5.00
8TJF StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £6.16
8TJF StarTech.com 6in Latching SATA Cable In Stock £2.60
8TJF StarTech.com 12in SATA to Left Angle SATA Serial ATA Cable In Stock £4.82
8TJF StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable In Stock £3.93
8TJF StarTech.com 6in SATA to Right Angle SATA Serial ATA Cable In Stock £3.90
8TJF StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £8.33
8TJF StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 Cable In Stock £23.61
8TJF StarTech.com USB 3.1 Adapter Cable w/ USB-C In Stock £17.59
8TJF StarTech.com USB 3.1 2.5/3.5" SATA Adapter In Stock £27.05
8TJF StarTech.com USB C to SATA Adapter Cable In Stock £34.82
8TJF StarTech.com 18in Right Angle SATA Cable In Stock £4.34
