StarTech.com USB 3.0 to SATA ODD Enclosure
Quicklinx: B7YPWS00 Mfr#: SLSODDU33B
Type: Storage enclosure
Stock Status: Clearance
Hurry, only 1 left in stock!
£12.38 ex VAT
£14.85 inc VAT
Express delivery Order within the next 18 hours for delivery on Thursday
Turn your Blu-ray or DVD ROM drive into a portable, external disk drive. This durable optical drive enclosure helps make your laptop, Ultrabook or tablet even more powerful by adding an external USB 3.0 Optical Disk Drive (ODD). Simply slide your slimline SATA Blu-ray, CD or DVD-ROM drive into this compact portable enclosure to add optical reading and writing support to your computer.
With USB 3.0 as the output interface, the drive enclosure supports up to 5Gbps transfer rate. Now you can access videos and other large files quickly to save valuable time while you're on the go.
With a durable, solid-aluminum housing, this top-quality external enclosure gives you the compact portability you need when you're on the move or in the field. Plus, the enclosure is USB-powered, so you won't have to carry a power adapter with you everywhere you go.
The optical drive enclosure is OS independent, so you can rest assured it's compatible with any operating system including Mac, Windows, Linux and Android.
It's also backward compatible with USB 2.0 and 1.1, so you'll be able to connect your optical drive to older computers.
StarTech.com USB 3.0 to Slimline SATA ODD Enclosure - storage enclosure - SATA 3Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Expansion Bays
1 x front accessible - 5.25" Slim Line
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
CD drive, DVD drive, BD drive
Product Material
Plastic, aluminium
13.6 cm x 15 cm x 2 cm
277 g
Host Bus
USB 3.0
Product Material
Plastic, aluminium
Storage Controller
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Initio
Bays
1 x SATA 3Gb/s - SATA combo
1 x USB 3.0 - 10 pin mini-USB
1 x USB cable - external
FCC, RoHS
13.6 cm
15 cm
2 cm
277 g
10 - 90%
B7YP StarTech.com Slimline SATA to SATA Adapter with Power - F/M In Stock £6.18
B7YP StarTech.com 3 ft Black SuperSpeed USB 3.0 Cable A to Micro B - M/M In Stock £6.40
B7YP StarTech.com 3 ft SuperSpeed USB 3.0 Cable A to Micro B In Stock £6.28
B7YP StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to Micro B In Stock £5.91
B7YP StarTech.com 12in Slimline SATA to SATA with LP4 Power Cable Adapter In Stock £5.92
B7YP StarTech.com 6in Slimline SATA to SATA Adapter with Power - F/M In Stock £7.16
B7YP StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M In Stock £6.10
B7YP StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £8.21
B7YP StarTech.com 1m (3ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £7.03
B7YP StarTech.com 0.5m (20in) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £6.09
B7YP StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £5.26
B7YP StarTech.com 10ft Slim Micro USB 3.0 Cable In Stock £10.79
Price Range Ex VAT: 0 - 50
