Turn your Blu-ray or DVD ROM drive into a portable, external disk drive. This durable optical drive enclosure helps make your laptop, Ultrabook or tablet even more powerful by adding an external USB 3.0 Optical Disk Drive (ODD). Simply slide your slimline SATA Blu-ray, CD or DVD-ROM drive into this compact portable enclosure to add optical reading and writing support to your computer.
With USB 3.0 as the output interface, the drive enclosure supports up to 5Gbps transfer rate. Now you can access videos and other large files quickly to save valuable time while you're on the go.
With a durable, solid-aluminum housing, this top-quality external enclosure gives you the compact portability you need when you're on the move or in the field. Plus, the enclosure is USB-powered, so you won't have to carry a power adapter with you everywhere you go.
The optical drive enclosure is OS independent, so you can rest assured it's compatible with any operating system including Mac, Windows, Linux and Android.
It's also backward compatible with USB 2.0 and 1.1, so you'll be able to connect your optical drive to older computers.
- StarTech.com USB 3.0 to Slimline SATA ODD Enclosure for Blu-ray & DVD ROM drives - Portable Optical Disk Drive Enclosure - Solid Aluminum (SLSODDU33B) - storage enclosure - SATA 3Gb/s - USB 3.0
- Storage enclosure - external
- Bus Type
- USB 3.0
- Black
- Expansion Bays
- 1 x front accessible - 5.25" Slim Line
- Interface
- SATA 3Gb/s
- Data Transfer Rate
- 3 Gbit/s
- Supported Devices
- CD drive, DVD drive, BD drive
- Product Material
- Plastic, aluminium
- 13.6 cm x 15 cm x 2 cm
- 277 g
- 2-year warranty
- Host Bus
- USB 3.0
- Product Material
- Black
Storage Controller
- Interface
- SATA 3Gb/s
- 3 Gbit/s
- Supported Devices
- Processor
- Initio
- Bays
- 1 x SATA 3Gb/s - SATA combo
- Connections
- 1 x USB 3.0 - 10 pin mini-USB
- Cables Included
- 1 x USB cable - external
- FCC, RoHS
- Limited warranty - 2 years
- 13.6 cm
- 15 cm
- 2 cm
- 277 g
- 0 °C
- 40 °C
- 10 - 90%
StarTech.com 12in Slimline SATA to SATA with LP4 Power Cable Adapter | In Stock | £7.12 |
StarTech.com 6in Slimline SATA to SATA Adapter with Power - F/M | In Stock | £9.00 |
StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M | In Stock | £7.36 |
StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £11.17 |
StarTech.com 0.5m (20in) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £7.74 |
StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £6.51 |
StarTech.com 10ft Slim Micro USB 3.0 Cable | In Stock | £12.99 |
