Enable fast, swappable access to your 2.5in or 3.5in SATA hard drives, through USB 3.0.
The SATDOCKU3S USB 3.0 Hard Drive Docking Station delivers full, instant access to any 2.5in or 3.5in SATA (SATA, SATA II, SATA III) hard drive (HDD) or solid state drive (SSD), without having to mount the drive in a computer or install it in an external enclosure. Large capacity drives (tested with up to 4TB) can be used to greatly enhance your computer's storage/backup capabilities.
Connected to the host computer through a single USB 3.0 SuperSpeed or USB 2.0 connection, the hard drive docking station provides a convenient, plug-and-play storage solution that delivers instant access to the hard drive without requiring a reboot.
Relying on the outstanding data throughput support of USB 3.0, the HDD docking station is capable of transfer speed up 5Gbps, making it the fastest way to access data from an external drive. Double the value of this hard drive docking station, using a SATA to IDE hard drive adapter (SAT2IDEADP), which enables you to use any 2.5 or 3.5in IDE hard drive in a SATA hard drive dock slot.
- StarTech.com SuperSpeed USB 3.0 to SATA Hard Drive Docking station for 2.5/3.5 HDD - HDD Docking station - SATA Dock - HDD docking station - SATA 3Gb/s - USB 3.0
- HDD docking station - external
- Bays
- 1
- Bus Type
- USB 3.0
- Black
- Expansion Bays
- 1 x hot-swap - 2.5" / 3.5" shared
- Hard Drive Form Factor Compatibility
- 2.5", 3.5"
- Interface
- SATA 3Gb/s
- Data Transfer Rate
- 3 Gbit/s
- Supported Devices
- Hard drive
- Power Source
- Included AC adapter
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows Server 2003, Apple MacOS X or later, Microsoft Windows 7, Microsoft Windows Vista / 2000 / XP, Microsoft Windows Server 2008
- 9.3 cm x 14.5 cm x 6.5 cm
- 410 g
- 2-year warranty
- Designed For
- P/N: PEXUSB3S23, PEXUSB3S24, PEXUSB3S25, PEXUSB3S42V, PEXUSB3S44V, PEXUSB3S4V, SAT2IDEADP, SVA12M2NEUA, SVA12M5NA, USB3SAB1, USBDUP15, USBDUPE115, USBDUPE17
- Bays
- 1
- 2.5", 3.5"
- Host Bus
- USB 3.0
- Black
Storage Controller
- Interface
- SATA 3Gb/s
- 3 Gbit/s
- Supported Devices
- Hard drive
- Bays
- 1 x SATA 3Gb/s - SATA power , 1 x SATA 3Gb/s - SATA
- Connections
- 1 x USB 3.0 - 9 pin USB Type B
- Cables Included
- 1 x USB cable - external , 1 x Serial ATA cable - external
- Tested with up to 4TB 5400 RPM 3.5” hard drives, tested with up to 1TB 5400 RPM 2.5” hard drives
- Plug and Play, FCC, RoHS
- Power Source
- Power adapter
- Voltage Required
- AC 120/230 V
- OS Required
- Limited warranty - 2 years
- 9.3 cm
- 14.5 cm
- 6.5 cm
- 410 g
- 5 °C
- 80 °C
- 8 - 80%
- Designed For
StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap | In Stock | £3.71 |
StarTech.com 3.5in Silicone Hard Drive Protector Sleeve with Connector Cap | In Stock | £4.06 |
StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD | In Stock | £38.35 |
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks | In Stock | £19.61 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) | In Stock | £12.19 |
StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps | In Stock | £41.76 |
StarTech.com USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP | In Stock | £38.91 |
StarTech.com eSATA / USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP | In Stock | £45.51 |
StarTech.com USB 3.1 Gen 2 Dual-bay Dock | In Stock | £81.93 |
StarTech.com USB 3.1 / eSATA 1-bay Dock | In Stock | £54.24 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £13.92 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £45.71 |
