Connect an additional HDMI display to your Mac or PC with USB 3.0 technology capable of video playback at 1080p. The USB32HDPRO USB 3.0 to HDMI Adapter lets you add an HDMI display to your computer through a USB 3.0 port, providing a cost-effective and convenient way to expand the video capabilities of your Mac or PC computer system.
With USB 3.0 support, this external video adapter delivers the bandwidth needed for accelerated High-Definition video performance, capable of outputting video resolutions up to 1920x1200 / 1080p. Even if your current computer doesn't have a USB 3.0 port available, the USB32HDPRO is backward compatible with USB 2.0, so you'll be able to connect your HDMI monitor to your computer and be ready for when you upgrade to a USB 3.0-equipped system.
Add the screen space you need to simplify multitasking and maximize productivity, without even opening your computer case. Some computer systems, including MacBook and Ultrabook laptops and small form-factor desktops, are too compact to install an internal video card. A USB display adapter offers an easy workaround, performing as an external video card that only requires an available USB port to mirror or extend your desktop onto another display.
Installation has never been easier. When you connect this DisplayLink Plug and Display certified adapter to a web-enabled Windows 10, Windows 8 or Windows 7 computer, it automatically downloads and installs the most up-to-date drivers for you, so you won't have to manually download or install any software.
USB 3.0 Bandwidth, High Definition Performance
With USB 3.0 support, this external video adapter delivers the bandwidth needed for accelerated High-Definition video performance, capable of outputting video resolutions up to 1920x1200 / 1080p. Even if your current computer doesn't have a USB 3.0 port available, the USB32HDPRO is backward compatible with USB 2.0, so you'll be able to connect your HDMI monitor to your computer and be ready for when you upgrade to a USB 3.0-equipped system. -
Easier Multitasking, More Productivity
Add the screen space you need to simplify multitasking and maximize productivity, without even opening your computer case. Some computer systems, including MacBook and Ultrabook laptops and small form-factor desktops, are too compact to install an internal video card. A USB display adapter offers an easy workaround, performing as an external video card that only requires an available USB port to mirror or extend your desktop onto another display. -
DisplayLink Plug-and-Display Certified
Installation has never been easier. When you connect this DisplayLink Plug and Display certified adapter to a web-enabled Windows 10, Windows 8 or Windows 7 computer, it automatically downloads and installs the most up-to-date drivers for you, so you won't have to manually download or install any software. The USB32HDPRO is backed by a StarTech.com 2-year warranty and free lifetime technical support. Recommended System Requirements: CPU: Quad Core 2.4GHz or Higher (i5 recommended) RAM: 4GB or higher
 - StarTech.com USB 3.0 to HDMI External Video Card Adapter - DisplayLink Certified - 1920x1200 - MultiMonitor Graphics Adapter - Supports Mac & Windows (USB32HDPRO) - adapter cable - HDMI / USB - 16 cm
- Cable
 - Adapter cable - HDMI / USB
- Max Output Resolution
 - 1920 x 1200
- Length
 - 16 cm
 - Black
- Connector
 - USB Type A - male (input)
- Connector (Second End)
 - HDMI - female (output)
 - USB 3.0/ USB 3.1
 - 1920 x 1200 (WUXGA) support
 - 2-year warranty
- Designed For
 - P/N: HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
- Cable Type
 - Adapter cable 1920 x 1200 (WUXGA) support
- Interface Supported
 - HDMI / USB
 - USB 3.0/ USB 3.1
- Length
 - 16 cm
 - Dolby DTS 5.1 support
 - Black
Adapters & Converters
 - 1920 x 1200
- OS Required
 - Microsoft Windows XP 32-bit, Apple MacOS X 10.6 - 10.12, Google Chrome OS 55 or later, Ubuntu 18.04, Ubuntu 20.04, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Connector
 - 9 pin USB Type A - male (input)
 - 19 pin HDMI Type A - female (output)
 - FCC, RoHS, DisplayLink Plug and Display, HDCP 1.4
 - 5.5 cm
 - 9 cm
 - 2 cm
 - 62 g
- Shipping Width
 - 14.5 cm
- Shipping Depth
 - 21.2 cm
- Shipping Height
 - 4 cm
- Shipping Weight
 - 196 g
 - Limited warranty - 2 years
- Designed For
                        StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.92 |
                        StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 | In Stock | £64.55 |
                        StarTech.com USB 3 to HDMI w/ USB Hub | In Stock | £22.35 |
                        StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £22.93 |
                        StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC | In Stock | £47.72 |
                        StarTech.com USB 3.0 to Dual HDMI Adapter | In Stock | £35.15 |
                        StarTech.com USB to Dual DisplayPort 4K 60Hz | In Stock | £78.39 |
