StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC
Quicklinx: 9TV9WS00 Mfr#: USB32HDPRO
Hurry, only 3 left in stock!
£48.92 ex VAT
£58.70 inc VAT
Connect an additional HDMI display to your Mac or PC with USB 3.0 technology capable of video playback at 1080p. The USB32HDPRO USB 3.0 to HDMI Adapter lets you add an HDMI display to your computer through a USB 3.0 port, providing a cost-effective and convenient way to expand the video capabilities of your Mac or PC computer system.
With USB 3.0 support, this external video adapter delivers the bandwidth needed for accelerated High-Definition video performance, capable of outputting video resolutions up to 1920x1200 / 1080p. Even if your current computer doesn't have a USB 3.0 port available, the USB32HDPRO is backward compatible with USB 2.0, so you'll be able to connect your HDMI monitor to your computer and be ready for when you upgrade to a USB 3.0-equipped system.
Add the screen space you need to simplify multitasking and maximize productivity, without even opening your computer case. Some computer systems, including MacBook and Ultrabook laptops and small form-factor desktops, are too compact to install an internal video card. A USB display adapter offers an easy workaround, performing as an external video card that only requires an available USB port to mirror or extend your desktop onto another display.
Installation has never been easier. When you connect this DisplayLink Plug and Display certified adapter to a web-enabled Windows 10, Windows 8 or Windows 7 computer, it automatically downloads and installs the most up-to-date drivers for you, so you won't have to manually download or install any software.
  • USB 3.0 Bandwidth, High Definition Performance
  • Easier Multitasking, More Productivity
  • DisplayLink Plug-and-Display Certified
    Installation has never been easier. When you connect this DisplayLink Plug and Display certified adapter to a web-enabled Windows 10, Windows 8 or Windows 7 computer, it automatically downloads and installs the most up-to-date drivers for you, so you won't have to manually download or install any software. The USB32HDPRO is backed by a StarTech.com 2-year warranty and free lifetime technical support. Recommended System Requirements: CPU: Quad Core 2.4GHz or Higher (i5 recommended) RAM: 4GB or higher
StarTech.com USB 3.0 to HDMI External Video Card Adapter - DisplayLink Certified - 1920x1200 - MultiMonitor Graphics Adapter - Supports Mac & Windows (USB32HDPRO) - adapter cable - HDMI / USB - 16 cm
Cable
Adapter cable - HDMI / USB
Max Output Resolution
1920 x 1200
Length
16 cm
Connector
USB Type A - male (input)
Connector (Second End)
HDMI - female (output)
USB 3.0/ USB 3.1
1920 x 1200 (WUXGA) support
P/N: HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
Cable Type
Adapter cable 1920 x 1200 (WUXGA) support
Interface Supported
HDMI / USB
USB 3.0/ USB 3.1
Length
16 cm
Dolby DTS 5.1 support
Adapters & Converters
1920 x 1200
Microsoft Windows XP 32-bit, Apple MacOS X 10.6 - 10.12, Google Chrome OS 55 or later, Ubuntu 18.04, Ubuntu 20.04, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Connector
9 pin USB Type A - male (input)
19 pin HDMI Type A - female (output)
FCC, RoHS, DisplayLink Plug and Display, HDCP 1.4
5.5 cm
9 cm
2 cm
62 g
Shipping Width
14.5 cm
Shipping Depth
21.2 cm
Shipping Height
4 cm
Shipping Weight
196 g
9TV9 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
9TV9 StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 In Stock £66.16
9TV9 StarTech.com USB 3 to HDMI w/ USB Hub In Stock £60.64
9TV9 StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £23.14
9TV9 StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC In Stock £48.92
9TV9 StarTech.com USB 3.0 to Dual HDMI Adapter In Stock £36.04
9TV9 StarTech.com USB to Dual DisplayPort 4K 60Hz In Stock £80.35
