Brand
StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter
Quicklinx: 8BM7WS00 Mfr#: USB32HDDVII
£88.61 ex VAT
£106.33 inc VAT
The USB32HDDVII USB 3.0 to HDMI and DVI-I Dual Head Adapter turns an available USB 3.0 port into one DVI-I or VGA port (DVI to VGA adapter included) and one HDMI output, with support for high-definition 1080p and 1920x1200 video and 5.1 surround sound audio (from HDMI port only). The adapter delivers a convenient external video solution that makes it easy to add multi-monitor capability to a USB-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the USB video adapter functions as a convenient external graphics card that eliminates having to open the computer case for video card installation. The adapter delivers smooth, high-definition content to multiple displays and can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop onto a second or third monitor to double or triple your workspace and increase your productivity.
StarTech.com USB 3.0 to HDMI / DVI Adapter - 2048x1152 - External Video & Graphics Card - Dual Monitor Display Adapter Cable - Supports Mac & Windows (USB32HDDVII) - adapter - HDMI / USB - TAA Compliant
Cable
Adapter - HDMI / USB
TAA Compliant
Max Output Resolution
2048 x 1152 - 60 Hz
Connectors
USB Type B - female
Connectors (Second End)
HDMI - female , DVI-I - female
USB / USB 2.0 / USB 3.0
2048 x 1152 support 60Hz
P/N: DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, DVISPL1DD, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
Cable Type
Adapter 2048 x 1152 support 60Hz
Interface Supported
HDMI / USB
Dolby DTS 5.1 support
Adapters & Converters
2048 x 1152
Refresh Rate
60 Hz
Microsoft Windows XP 32-bit, Ubuntu 14.04, Microsoft Windows 7 / 8 / 8.1 / 10, Ubuntu 16.04, Apple MacOS X 10.6 - 10.12, Google Chrome OS 55 or later, Ubuntu 18.04, Apple MacOS X 10.14 - 10.15, Apple MacOS X 11.0
Connectors
9 pin USB Type B - female
19 pin HDMI Type A - female , 24+5 pin combined DVI - female
DVI to VGA adapter, USB 3.0 cable (1 m)
TAA Compliant
5 cm
7.3 cm
1.9 cm
43 g
Shipping Width
20.6 cm
Shipping Depth
14.5 cm
Shipping Height
4 cm
Shipping Weight
240 g
8BM7 StarTech.com 15 ft DVI-D Dual Link Cable - M/M In Stock £15.69
8BM7 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £8.25
8BM7 StarTech.com USB to DVI External Video Card Multi Monitor Adapter – 1920x1200 In Stock £58.31
8BM7 StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 In Stock £78.45
8BM7 StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter In Stock £88.61
8BM7 StarTech.com USB to DVI Adapter - External USB Video Graphics Card for PC and MAC- 1920x1200 In Stock £60.47
8BM7 StarTech.com USB 3.0 to DVI External Video Card Multi Monitor Adapter with 1-Port USB Hub 1920x1200 In Stock £48.88
8BM7 StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £58.12
8BM7 StarTech.com USB 3.0 to Dual HDMI Adapter In Stock £65.02
8BM7 StarTech.com USB 3.0 to HDMI VGA Adapter - 4K 30 - External Video & Graph In Stock £98.46
Stock Status: In stock
