The USB32HDDVII USB 3.0 to HDMI and DVI-I Dual Head Adapter turns an available USB 3.0 port into one DVI-I or VGA port (DVI to VGA adapter included) and one HDMI output, with support for high-definition 1080p and 1920x1200 video and 5.1 surround sound audio (from HDMI port only). The adapter delivers a convenient external video solution that makes it easy to add multi-monitor capability to a USB-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the USB video adapter functions as a convenient external graphics card that eliminates having to open the computer case for video card installation. The adapter delivers smooth, high-definition content to multiple displays and can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop onto a second or third monitor to double or triple your workspace and increase your productivity.
- StarTech.com USB 3.0 to HDMI / DVI Adapter - 2048x1152 - External Video & Graphics Card - Dual Monitor Display Adapter Cable - Supports Mac & Windows (USB32HDDVII) - adapter - HDMI / USB - TAA Compliant
- Cable
- Adapter - HDMI / USB
- TAA Compliant
- Max Output Resolution
- 2048 x 1152 - 60 Hz
- Black
- Connectors
- USB Type B - female
- Connectors (Second End)
- HDMI - female , DVI-I - female
- USB / USB 2.0 / USB 3.0
- 2048 x 1152 support 60Hz
- 2-year warranty
- Designed For
- P/N: DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, DVISPL1DD, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
- Cable Type
- Adapter 2048 x 1152 support 60Hz
- Interface Supported
- HDMI / USB
- Dolby DTS 5.1 support
- Black
Adapters & Converters
- 2048 x 1152
- Refresh Rate
- 60 Hz
- OS Required
- Microsoft Windows XP 32-bit, Apple MacOS X 10.6 - 10.12, Google Chrome OS 55 or later, Ubuntu 18.04, Ubuntu 20.04, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Connectors
- 9 pin USB Type B - female
- 19 pin HDMI Type A - female , 24+5 pin combined DVI - female
- Included Accessories
- DVI to VGA adapter, USB 3.0 cable (1 m)
- TAA Compliant
- 5 cm
- 7.3 cm
- 1.9 cm
- 43 g
- Shipping Width
- 20.6 cm
- Shipping Depth
- 14.5 cm
- Shipping Height
- 4 cm
- Shipping Weight
- 240 g
- Limited warranty - 2 years
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.74 |
StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 | In Stock | £66.16 |
StarTech.com USB to DVI Adapter - External USB Video Graphics Card for PC and MAC- 1920x1200 | In Stock | £65.01 |
StarTech.com USB 3 to HDMI w/ USB Hub | In Stock | £60.64 |
StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £22.64 |
StarTech.com USB 3.0 to Dual HDMI Adapter | In Stock | £35.24 |
StarTech.com USB to Dual DisplayPort 4K 60Hz | In Stock | £80.35 |
StarTech.com USB 3.0 to HDMI VGA Adapter - 4K 30 - External Video & Graph | In Stock | £62.06 |
StarTech.com USB to Dual HDMI Adapter | In Stock | £46.04 |
StarTech.com USB-C to Dual-HDMI Adapter | In Stock | £86.45 |
