StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps
Quicklinx: 8SFNWS00 Mfr#: USB31000NDS
Wired / Wireless: Wired
Protocol: Fast Ethernet, Ethernet, Gigabit Ethernet
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
More than 50 In Stock
£20.60 ex VAT
£24.72 inc VAT
Add Gigabit Ethernet network connectivity to a Laptop or Desktop through a USB 3.0 port. The USB31000NDS USB 3.0 to Gigabit Ethernet Network Adapter adds a single RJ45 Ethernet port to a USB-enabled computer system, with support for Gigabit network connections at full bandwidth when used with a USB 3.0 host connection, unlike USB 2.0 adapters.
This compact USB 3.0 NIC works with 10/100/1000 Mbps networks and offers backward compatibility with USB 2.0/1.x computer systems (speed limited by USB bus), making it an ideal portable replacement LAN adapter or laptop accessory. Support for features such as Jumbo Frames, VLAN tagging and Wake on LAN (WOL), provides versatile Gigabit network performance for home or business use.
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter - 10/100/100 Mbps Network Adapter - USB to Ethernet LAN Adapter - USB to RJ45 (USB31000NDS) - network adapter - USB 3.0 - Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
2.26 cm x 6.8 cm x 2.6 cm
21 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
ASIX AX88179
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
Network adapter
External
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
Wired
Cabling Type
Status Indicators
Link/activity
Auto-uplink (auto MDI/MDI-X), USB powered, IPv4 and IPv6 Large Send Offload and Checksum Offload (LSO/TCO), Jumbo Frames support, VLAN Tagging (not supported in MacOS)
Processor / Memory
ASIX AX88179
1 x 1000Base-T - RJ-45 - female
FCC, RoHS
Software Included
Drivers & Utilities
2.26 cm
6.8 cm
2.6 cm
21 g
50 °C
10 - 90%
8SFN StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter In Stock £24.00
8SFN StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White In Stock £38.92
8SFN StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter - White In Stock £21.30
8SFN StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps In Stock £20.60
8SFN StarTech.com USB 3.0 to Dual Port Gigabit Ethernet Adapter NIC w/ USB Port In Stock £52.45
8SFN StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black In Stock £29.98
8SFN StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - White In Stock £28.24
8SFN StarTech.com USB 2.0 to 10/100 Mbps Ethernet Network Adapter Dongle In Stock £14.10
8SFN StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £40.26
8SFN StarTech.com USB 3.0 Network Adapter-Silver In Stock £25.05
8SFN StarTech.com USB to Ethernet Adapter - 1Gb In Stock £20.00
Protocol: Ethernet
Protocol: Gigabit Ethernet
Compatibility: Mac
Compatibility: PC
