Add Gigabit Ethernet network connectivity to a Laptop or Desktop through a USB 3.0 port. The USB31000NDS USB 3.0 to Gigabit Ethernet Network Adapter adds a single RJ45 Ethernet port to a USB-enabled computer system, with support for Gigabit network connections at full bandwidth when used with a USB 3.0 host connection, unlike USB 2.0 adapters.
This compact USB 3.0 NIC works with 10/100/1000 Mbps networks and offers backward compatibility with USB 2.0/1.x computer systems (speed limited by USB bus), making it an ideal portable replacement LAN adapter or laptop accessory. Support for features such as Jumbo Frames, VLAN tagging and Wake on LAN (WOL), provides versatile Gigabit network performance for home or business use.
Versatile compatibility
This network adapter is compatible with Mac systems, allowing users to connect to wired networks effortlessly. -
Fast data transfer
Achieves data transfer rates of up to 1000 Mbps, ensuring quick and efficient network access. -
Easy setup
USB-powered design allows for simple connection without the need for additional power adapters, streamlining the user experience. -
Reliable connectivity
Supports various Ethernet protocols including Gigabit Ethernet, ensuring a stable and fast network connection. -
Auto-uplink for ease of use
Features auto-uplink capability to automatically detect and configure for optimal connectivity with network devices.
- StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter - 10/100/100 Mbps Network Adapter - USB to Ethernet LAN Adapter - USB to RJ45 (USB31000NDS) - network adapter - USB 3.0 - Gigabit Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- Gigabit Ethernet
- 2.26 cm x 6.8 cm x 2.6 cm
- 21 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Processor
- ASIX AX88179
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab
- Black
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
- 2-year warranty
- Network adapter
- Form Factor
- External
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- Status Indicators
- Link/activity
- Auto-uplink (auto MDI/MDI-X), USB powered, IPv4 and IPv6 Large Send Offload and Checksum Offload (LSO/TCO), Jumbo Frames support, VLAN Tagging (not supported in MacOS)
Processor / Memory
- Processor
- ASIX AX88179
- 1 x 1000Base-T - RJ-45 - female
- FCC, RoHS
- Black
- Software Included
- Drivers & Utilities
- OS Required
- 2.26 cm
- 6.8 cm
- 2.6 cm
- 21 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 10 - 90%
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £21.26 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter | In Stock | £23.36 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White | In Stock | £38.00 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter - White | In Stock | £20.71 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps | In Stock | £20.19 |
StarTech.com USB 3.0 to Dual Port Gigabit Ethernet Adapter NIC w/ USB Port | In Stock | £52.06 |
StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black | In Stock | £29.53 |
StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - White | In Stock | £27.51 |
StarTech.com USB 2.0 to 10/100 Mbps Ethernet Network Adapter Dongle | In Stock | £13.59 |
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable | In Stock | £39.78 |
StarTech.com USB 3.0 Network Adapter-Silver | In Stock | £23.74 |
StarTech.com USB to Ethernet Adapter - 1Gb | In Stock | £19.76 |
