StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - White
Quicklinx: 91F3WS00 Mfr#: USB31000SPTW
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
Hurry, only 3 left in stock!
£25.65 ex VAT
£30.78 inc VAT
Add a Gigabit Ethernet port and a USB 3.0 pass-through port to your laptop through a single USB 3.0 port. The USB31000SPTW USB 3.0 to Gigabit Ethernet Adapter lets you add a Gigabit network port to your Macbook or Ultrabook computer through a USB 3.0 port, and features an integrated USB 3.0 pass-through port that keeps your USB port available for use with other peripherals. The RJ45 port supports 10/100/1000 Mbps Ethernet and is fully compatible with IEEE 802.3i/u/ab standards.
An ideal replacement LAN adapter or laptop accessory, this compact USB 3.0 NIC leverages the 5 Gbps speed of USB 3.0 to provide full gigabit bandwidth and also offers backward compatibility with USB 2.0 systems (speed limited by USB bus).
The adapter supports features such as IPv4/IPv6 packet Checksum Offload Engine (COE) and TCP large send offload to reduce the load on your CPU. Jumbo Frames, full-duplex operation with 802.3x flow control and VLAN tagging are also supported, making this an efficient and full-featured USB network adapter.
StarTech.com USB 3 to Gigabit Ethernet Adapter NIC w/ USB Port - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
3.5 cm x 8.2 cm x 1.7 cm
50 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
AX88179 - ASIX
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x
White
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux Kernel 2.6.25 - 4.11.x LTS versions, Microsoft Windows Server 2019
Network adapter
External
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
Wired
Cabling Type
Status Indicators
Port transmission speed, link/activity
Flow control, full duplex capability, auto-uplink (auto MDI/MDI-X), USB powered, IPv4 and IPv6 Large Send Offload and Checksum Offload (LSO/TCO), Jumbo Frames support
Processor / Memory
AX88179 - ASIX
1 x 1000Base-T - RJ-45 - female , 1 x USB 3.0 - 9 pin USB Type A - female
1 x USB cable (integrated) - 15.24 cm
FCC, RoHS
White
Software Included
Drivers & Utilities
3.5 cm
8.2 cm
1.7 cm
50 g
50 °C
5 - 85%
91F3 StarTech.com 6 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £3.35
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: Mac
Compatibility: PC
Price Range Ex VAT: 0 - 50
