Connect an eSATA storage device to a USB 3.0 port on your laptop or desktop. The USB3S2ESATA3 USB 3.0 to eSATA drive cable lets you connect any eSATA hard drive, solid state drive, or optical disc drive to your USB-enabled computer system - a great solution for computers that don't natively support eSATA, such as MacBook and Ultrabook computers.
To maximize performance and utilize the speed potential of your SATA 6 Gbps drives, the USB 3.0 to eSATA adapter is compatible with SATA revisions I/II/III and supports transfer speeds up to 5 Gbps through USB 3.0.
With support for Blu-ray/DVD/CD ATAPI / ODD drives and large capacity HDD / SSDs (tested up to 4TB) the USB to eSATA adapter cable is compatible with virtually any eSATA device, and can greatly increase the storage/backup capabilities of your computer.
The USB 3.0 to eSATA drive cable ensures a hassle-free connection with simple plug-and-play installation, plus the cable is the perfect length (1-meter, end-to-end) for easily accessing the rear panel USB ports on your computer.
- StarTech.com 3 ft USB 3.0 to eSATA Adapter - 6 Gbps USB to HDD/SSD/ODD Converter - Hard Drive to USB Cable (USB3S2ESATA3) - storage controller - eSATA 6Gb/s - USB 3.0
- Storage controller - external
- Bus Type
- USB 3.0
- Interface
- eSATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Supported Devices
- Hard drive, solid state drive
- Max Storage Devices Qty
- 1
- 2.5 cm x 80 cm x 1 cm
- 137 g
- 2-year warranty
- Host Bus
- USB 3.0
Storage Controller
- Interface
- eSATA 6Gb/s
- 600 MBps
- Supported Devices
- 1
- Processor
- ASMedia ASM1153E
- 1 x eSATA 6Gb/s - eSATA
- Connections
- 1 x USB 3.0 - 9 pin USB Type A
- Cables Included
- 1 x USB cable - integrated - 80 cm
- FCC, RoHS
- Limited warranty - 2 years
- 2.5 cm
- 80 cm
- 1 cm
- 137 g
- 0 °C
- 60 °C
- 40 - 85%
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £24.08 |
StarTech.com USB 2.0 to SATA/IDE Combo Adapter for 2.5/3.5" SSD/HDD | In Stock | £22.31 |
StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP | In Stock | £31.16 |
StarTech.com USB 3.0 to SATA or IDE Hard Drive Adapter Converter | In Stock | £28.55 |
StarTech.com 2 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card w/ SATA Power | In Stock | £16.06 |
StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power | In Stock | £18.73 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels | In Stock | £61.44 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels | In Stock | £72.13 |
StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable | In Stock | £8.59 |
StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA Power | In Stock | £21.44 |
StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 Cable | In Stock | £23.17 |
