StarTech.com USB 3.0 to DVI External Video Card Multi Monitor Adapter with 1-Port USB Hub  1920x1200
Quicklinx: 8NV8WS00 Mfr#: USB32DVIEH
Connect a DVI-equipped display through USB 3.0, while keeping the USB 3.0 port available. The USB32DVIEH USB 3.0 to DVI Adapter turns an available USB 3.0 port into a DVI output port with high resolution 1920x1200 video support. The adapter features a built-in 1-Port USB 3.0 hub, which offers a connection port in place of the USB port used for connecting the DVI adapter - an ideal workaround for Ultrabook or laptop users where only a limited number of USB ports are available.
The USB to DVI adapter functions as an external graphics card, providing a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0). The included DVI to VGA adapter also allows you to use this device with a VGA display.
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your DVI display / projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
StarTech.com USB 3.0 to DVI Adapter with 1 Port USB Hub - 1920x1200 - External Video & Graphics Card - Dual Monitor Display Adapter - Supports Windows (USB32DVIEH) - external video adapter - T5-302 - 16 MB - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Graphics Engine
MCT Trigger 5 T5-302 - up to
16 MB DDR2
Max Resolution
1920 x 1200
Interfaces Details
DVI-I (dual link) , USB 3.0 , VGA - with adapter
4.9 cm x 8.5 cm x 1.7 cm
Enclosure Colour
P/N: DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, DVISPL1DD, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
Bus Type
SuperSpeed USB 3.0
Graphics Engine
Max Resolution
1920 x 1200
Interfaces Details
USB powered, USB Pass-Through
Size
16 MB
DDR2 SDRAM
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Min Processor Type
Intel Core i3 2.8 GHz
Min RAM Size
2 GB
1 x DVI-VGA adapter , 1 x USB cable - 16 cm
FCC, RoHS
4.9 cm
8.5 cm
1.7 cm
75 g
Enclosure Colour
50 °C
0 - 85% (non-condensing)
8NV8 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
8NV8 StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 In Stock £66.16
8NV8 StarTech.com USB to DVI Adapter - External USB Video Graphics Card for PC and MAC- 1920x1200 In Stock £65.01
