Connect a DVI display through SuperSpeed USB 3.0, for an accelerated external multi-monitor solution at resolutions up to 2048x1152. The USB32DVIPRO USB 3.0 to DVI Adapter turns an available USB 3.0 port into a DVI output, with high resolution 2048x1152 video support - a convenient external video solution that makes it easy to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0). Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter functions as an external graphics card to deliver smooth, high-resolution content to your DVI or VGA-capable display (DVI to VGA Adapter included). The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
- StarTech.com USB 3.0 to DVI / VGA Adapter - 2048x1152 - External Video & Graphics Card - Dual Monitor Display Adapter Cable - Supports Mac & Windows (USB32DVIPRO) - USB / DVI adapter - USB Type A to DVI-I - 15.2 cm
- USB / DVI adapter
- 2048 x 1152 support, plastic housing, 512 MB memory
- Length
- 15.2 cm
- Connector
- 9 pin USB Type A - male (input)
- Connector (Second End)
- 24+5 pin combined DVI - female (output)
- USB / USB 2.0 / USB 3.0
- Black
- 2-year warranty
- Designed For
- P/N: DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, DVISPL1DD, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
- USB / DVI adapter
- Length
- 15.2 cm
- Black
- 4.35 cm
- 7.8 cm
- 1.55 cm
- 91 g
- Connector
- Included Accessories
- DVI to VGA adapter
- USB / USB 2.0 / USB 3.0, FCC, RoHS, DisplayLink Plug and Display
- Shipping Width
- 14.4 cm
- Shipping Depth
- 17.1 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 211 g
- 2-year warranty
- Designed For
|  | StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.91 |
|  | StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 | In Stock | £64.55 |
|  | StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter | In Stock | £42.49 |
|  | StarTech.com USB to DVI Adapter - External USB Video Graphics Card for PC and MAC- 1920x1200 | In Stock | £63.44 |
|  | StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC | In Stock | £47.72 |
