StarTech.com USB 3.0 to DisplayPort External Video Card Multi Monitor Adapter – 2560x1600
Quicklinx: 89Z2WS00 Mfr#: USB32DPPRO
Connect a DisplayPort-equipped display through USB 3.0, for an HD external multi-monitor solution. The USB32DPPRO USB 3.0 to DisplayPort Multi Monitor Adapter functions as an external DisplayPort video card, turning an available USB 3.0 port into a DisplayPort output, with support for high resolution 2560x1600 video, and 5.1 surround sound audio. The USB 3.0 DisplayPort adatper delivers a convenient, high-performance external video solution that makes it easy to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your DisplayPort-capable display, and can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
StarTech.com USB 3.0 to DisplayPort External Video Multi Monitor Adapter - external video adapter - DisplayLink DL-3500 - 64 MB - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Graphics Engine
DisplayLink DL-3500 - up to
64 MB DDR2
Max Resolution
2560 x 1600
Interfaces Details
DisplayPort
2.64 cm x 8.12 cm x 1.12 cm
Enclosure Colour
P/N: MDP2DPMM10, MDP2DPMM3, MDP2DPMM6, MDP2DVIMM6BS
Bus Type
SuperSpeed USB 3.0
Graphics Engine
DisplayLink DL-3500
Max Resolution
2560 x 1600
Interfaces Details
DisplayPort
USB powered
Size
64 MB
DDR2 SDRAM
Ubuntu 14.04, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Ubuntu 16.04, Google Chrome OS 55 or later, Apple MacOS X 10.6 - 10.13.3
Min Processor Type
Dual core processor 2.8 GHz
Min RAM Size
2 GB
1 x SuperSpeed USB cable - 90 cm
Software Included
Drivers & Utilities
FCC, RoHS
2.64 cm
8.12 cm
1.12 cm
30 g
Enclosure Colour
35 °C
89Z2 StarTech.com USB to VGA Multi Monitor External Video Adapter In Stock £15.41
89Z2 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
