StarTech.com USB 3.0 to DisplayPort Adapter
Quicklinx: D9CBWS00 Mfr#: USB32DPES2
Length: 20cm
£54.04 ex VAT
£64.84 inc VAT
This USB to DisplayPort adapter lets you connect your computer to a 4K DisplayPort monitor using a USB 3.0 Type A port, even if your computer doesn’t support 4K video.
  • High-resolution display support
    With a maximum output resolution of 3840 x 2160, this adapter allows for crisp and detailed images, enhancing visual clarity for work or entertainment.
  • Efficient connectivity
    Featuring a male 9-pin USB Type-A connector and a female 20-pin DisplayPort connector, this adapter ensures easy connection to various devices without the need for complex setup.
  • Reliable performance
    The integrated 64 MB memory enhances the adapter's performance, providing a stable connection and smooth video playback.
StarTech.com USB 3.0 to DisplayPort Adapter - 4K 30Hz - External Video & Graphics Card - Dual Monitor Display Adapter - Supports Windows (USB32DPES2) - DisplayPort adapter - USB Type A to DisplayPort - TAA Compliant - 20 cm
DisplayPort adapter
4K30Hz (3840 x 2160) support, plastic housing, 64 MB memory
Length
20 cm
Connector
9 pin USB Type A - male (input)
Connector (Second End)
20 pin DisplayPort - female (output)
USB 3.0
TAA Compliant
DisplayPort adapter
Length
20 cm
5.5 cm
7.5 cm
1.6 cm
58 g
Connector
USB 3.0, FCC, RoHS
TAA Compliant
Shipping Width
14.4 cm
Shipping Depth
21 cm
Shipping Height
3.8 cm
Shipping Weight
190 g
D9CB StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
D9CB StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £23.14
D9CB StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £19.04
D9CB StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £6.89
D9CB StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.78
Length: 20cm
