This USB to DisplayPort adapter lets you connect your computer to a 4K DisplayPort monitor using a USB 3.0 Type A port, even if your computer doesn’t support 4K video.
High-resolution display support
With a maximum output resolution of 3840 x 2160, this adapter allows for crisp and detailed images, enhancing visual clarity for work or entertainment. -
Efficient connectivity
Featuring a male 9-pin USB Type-A connector and a female 20-pin DisplayPort connector, this adapter ensures easy connection to various devices without the need for complex setup. -
Reliable performance
The integrated 64 MB memory enhances the adapter's performance, providing a stable connection and smooth video playback.
- StarTech.com USB 3.0 to DisplayPort Adapter - 4K 30Hz - External Video & Graphics Card - Dual Monitor Display Adapter - Supports Windows (USB32DPES2) - DisplayPort adapter - USB Type A to DisplayPort - TAA Compliant - 20 cm
- 4K30Hz (3840 x 2160) support, plastic housing, 64 MB memory
- Length
- 20 cm
- Connector
- 9 pin USB Type A - male (input)
- Connector (Second End)
- 20 pin DisplayPort - female (output)
- USB 3.0
- Black
- TAA Compliant
- 2-year warranty
- Length
- 20 cm
- Black
- 5.5 cm
- 7.5 cm
- 1.6 cm
- 58 g
- Connector
- USB 3.0, FCC, RoHS
- TAA Compliant
- Shipping Width
- 14.4 cm
- Shipping Depth
- 21 cm
- Shipping Height
- 3.8 cm
- Shipping Weight
- 190 g
- 2-year warranty
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.08 |
StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £27.98 |
StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £19.75 |
StarTech.com 1m 3.3ft DisplayPort 1.4 Cable | In Stock | £6.91 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £12.15 |
