StarTech.com USB 3.0 to 4K HDMI External Multi Monitor Video Graphics Adapter
Quicklinx: 9X8ZWS00 Mfr#: USB32HD4K
Connect an additional HDMI display to your PC with USB 3.0 technology capable of playback at 4K. Want to add 4K Ultra HD video to your computer system? Now, you can enjoy the picture quality of Ultra HD video, even if your system doesn't natively support 4K video output.
With an additional 4K monitor connected to your computer, you can extend or mirror your desktop for increased productivity. DisplayLink 4K Plug-and-Display certification ensures automatic driver installation, so you'll be ready to enjoy your Ultra HD display in no time.
Now you can connect a 4K HDTV, monitor or projector to your computer, even if your laptop or desktop video card doesn't natively support 4K output. The USB32HD4K USB to HDMI 4K adapter lets you extend or mirror your primary display onto an Ultra HD monitor or television, giving you the additional screen space you need to simplify multi-tasking and maximize your productivity.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television; the USB32HD4K lets you harness the impressive bandwidth capability of a USB 3.0 connection to deliver the astonishing quality of Ultra HD to your 4K display. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
Installation has never been easier. When you connect this DisplayLink 4K Plug-and-Display certified adapter to a web-enabled Windows 7, Windows 8 or Windows 10 computer, it automatically downloads and installs the most up-to-date drivers for you, so you won't have to.
  • Enhance Your Productivity
    Functioning as an USB external graphics card, this display adapter provides a convenient way to add multi-monitor capability to a USB 3.0 desktop or laptop computer. Leveraging the USB 3.0 interface, the adapter delivers ultrahigh definition content to your HDMI display. The adapter can be used to increase workstation productivity by extending your desktop or mirror your primary display The lightweight adapter dongle features a small footprint, making it the perfect accessory for professionals who work remotely from home or in an office environment.
  • 4K Picture Quality
    The HDMI output on this USB 3.0 video adapter supports UHD resolutions up to 4K 30Hz. Even if your laptop or desktop video card doesn't natively support 4K output, the adapter allows you to connect a 4K HDTV, monitor or projector. For added convenience, the adapter is backward compatible with 1080p video resolutions.
  • DisplayLink 4K Plug-and-Display Certified
    Installation has never been easier. When you connect this DisplayLink 4K Plug-and-Display certified adapter to a Windows computer, it automatically downloads and installs the most up-to-date drivers for you, so you won't have to. This USB to HDMI adapter is compatible with any operating system, including Windows, macOS, ChromeOS and Linux. USB32HD4K is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Startech USB 3.0 to HDMI Adapter, 4K 30Hz Ultra HD, DisplayLink Certified, USB Type-A to HDMI Display Adapter Converter for Monitor, External Video & Graphics Card, Mac & Windows - USB to HDMI Adapter (USB32HD4K) - adapter cable - HDMI / USB - TAA Compliant - 20 cm
Cable
Adapter cable - HDMI / USB
TAA Compliant
Max Output Resolution
3840 x 2160 - 30 Hz
Cable Length
20 cm
Connector
USB Type A - male (input)
Connector (Second End)
HDMI - female (output)
USB 2.0/ USB 3.0
USB power + audio
P/N: HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
Cable Type
Adapter cable USB power + audio
Interface Supported
HDMI / USB
Jacket Material
Plastic
USB 2.0/ USB 3.0
Cable Length
20 cm
Multi-channel audio
Adapters & Converters
3840 x 2160
Refresh Rate
30 Hz
Microsoft Windows XP 32-bit, Apple MacOS X 10.6 - 10.12, Google Chrome OS 55 or later, Ubuntu 18.04, Ubuntu 20.04, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Connector
9 pin USB Type A - male (input)
19 pin HDMI Type A - female (output)
WHQL, FCC, RoHS, WEEE, REACH, DisplayLink Plug and Display, RCM
TAA Compliant
4.5 cm
1.5 cm
65 g
Shipping Width
14.5 cm
Shipping Depth
21.2 cm
Shipping Height
4.1 cm
Shipping Weight
198 g
9X8Z StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
9X8Z StarTech.com USB 3 to HDMI w/ USB Hub In Stock £60.64
9X8Z StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £23.14
9X8Z StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC In Stock £51.16
9X8Z StarTech.com USB 3.0 to Dual HDMI Adapter In Stock £36.04
9X8Z StarTech.com USB 3.0 to DisplayPort Adapter In Stock £54.04
9X8Z StarTech.com USB to Dual DisplayPort 4K 60Hz In Stock £80.35
