StarTech.com USB 3.0 to 4K DisplayPort External Multi Monitor Video Graphics Adapter
Quicklinx: 9XDGWS00 Mfr#: USB32DP4K
More than 50 In Stock
£63.29 ex VAT
£75.94 inc VAT
Connect an additional DisplayPort monitor to your PC with USB 3.0 technology capable of playback at 4K. Want to add 4K Ultra HD video to your computer system? Now, you can enjoy the picture quality of Ultra HD video, even if your system doesn't natively support 4K video output. With an additional 4K monitor connected to your computer, you can extend or mirror your desktop for increased productivity. DisplayLink 4K Plug-and-Display certification ensures automatic driver installation, so you'll be ready to enjoy your Ultra HD display in no time.
Now you can connect a 4K HDTV, monitor or projector to your computer, even if your laptop or desktop video card doesn't natively support 4K output. The USB32DP4K USB to DisplayPort 4K adapter lets you extend or mirror your primary display onto an Ultra HD monitor or television, giving you the additional screen space you need to simplify multi-tasking and maximize your productivity.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television; the USB32DP4K lets you harness the impressive bandwidth capability of a USB 3.0 connection to deliver the astonishing quality of Ultra HD to your 4K display. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
Installation has never been easier. When you connect this DisplayLink 4K Plug-and-Display certified adapter to a web-enabled Windows 7, Windows 8 or Windows 10 computer, it automatically downloads and installs the most up-to-date drivers for you, so you won't have to.
  • Ultra HD Multi-tasking
  • Astonishing Picture Quality
  • DisplayPort & DisplayLink 4K Plug-and-Display Certified
    Installation has never been easier. When you connect this DisplayLink 4K Plug-and-Display certified adapter to a web-enabled Windows 7, Windows 8, Windows 10 orWindows 11 computer, it automatically downloads and installs the most up-to-date drivers for you, so you won't have to. The USB32DP4K is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com USB 3.0 to DisplayPort Adapter - DisplayLink Certified - 4K 30Hz - USB / DisplayPort adapter - USB Type A to DisplayPort - TAA Compliant - 9 m
4K support, USB power
Length
9 m
Connector
9 pin USB Type A - male (input)
Connector (Second End)
20 pin DisplayPort - female (output)
USB 3.0
TAA Compliant
P/N: MDP2DPMM10, MDP2DPMM3, MDP2DPMM6, MDP2DVIMM6BS, TB33A1C
Jacket Material
Plastic
Length
9 m
4.5 cm
1.5 cm
60 g
Connector
USB 3.0, FCC, RoHS, WEEE, REACH, DisplayLink Plug and Display, RCM
TAA Compliant
Shipping Width
14.4 cm
Shipping Depth
21.1 cm
Shipping Height
3.8 cm
Shipping Weight
204 g
9XDG StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.05
9XDG StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter In Stock £66.69
9XDG StarTech.com USB 3 to HDMI w/ USB Hub In Stock £62.21
9XDG StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £27.98
9XDG StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC In Stock £49.78
9XDG StarTech.com USB 3.0 to 4K DisplayPort External Multi Monitor Video Graphics Adapter In Stock £63.29
9XDG StarTech.com USB to Dual DisplayPort 4K 60Hz In Stock £81.78
9XDG StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £13.02
9XDG StarTech.com 2m 6.6ft DisplayPort 1.4 Cable In Stock £15.18
9XDG StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.12
9XDG StarTech.com 6ft DisplayPort 1.4 8K 60Hz In Stock £15.57
