Connect a 2.5in SATA hard drive to your computer using a portable cable with UASP Support. The USB3S2SAT3CB USB 3.0 to SATA adapter cable lets you connect a 2.5" SATA hard drive or solid state drive to your computer through an available USB port. The cable supports UASP, allowing for transfer speeds up to 70% faster than conventional USB 3.0, which enables you to utilize the full potential of your SATA III SSD/HDD, when paired with a UASP-enabled host controller.
his portable, cable-style adapter makes it easy to swap between hard drives without having to install your drives in an enclosure, and features a lightweight design with no external power required, for easy storage in a laptop bag or carrying case.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing, UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
- StarTech.com SATA to USB Cable - USB 3.0 to 2.5" SATA III Hard Drive Adapter - External Converter for SSD/HDD Data Transfer (USB3S2SAT3CB) - storage controller - SATA 6Gb/s - USB 3.0
- Storage controller - external
- Bus Type
- USB 3.0
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- 4.5 cm x 50 cm x 1 cm
- 189 g
- 2-year warranty
- 2.5"
- Host Bus
- USB 3.0
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Processor
- ASMedia ASM1051E
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.0 - 9 pin USB Type B
- Cables Included
- 1 x USB cable - external
- FCC, RoHS
- OS Required
- Limited warranty - 2 years
- 4.5 cm
- 50 cm
- 1 cm
- 189 g
- 0 °C
- 60 °C
- 40 - 85%
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £28.42 |
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £25.64 |
StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP | In Stock | £36.81 |
StarTech.com 1 Port Flush Mount ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £20.71 |
StarTech.com USB 3.0 to SATA or IDE Hard Drive Adapter Converter | In Stock | £33.68 |
StarTech.com 2.5in Aluminum USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP for SATA 6 | In Stock | £23.45 |
StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable | In Stock | £8.94 |
StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 Cable | In Stock | £28.25 |
StarTech.com USB 3.1 Gen 2 Adapter Cable | In Stock | £15.15 |
StarTech.com USB 3.1 Adapter Cable w/ USB-C | In Stock | £18.92 |
StarTech.com 2m USB 3.0 C Cable w/ PD (3A) | In Stock | £21.00 |
StarTech.com CFast Card Reader - USB 3.0 | In Stock | £22.18 |
StarTech.com CFast Card Reader - USB-C | In Stock | £27.93 |
StarTech.com USB 3.0 to eSATA HDD/SSD/ODD Adapter Cable – USB-C | In Stock | £29.98 |
