StarTech.com USB 3.0 SD/microSD Card Reader
Quicklinx: CX8ZWS00 Mfr#: SDMSDRWU3AC
More than 50 In Stock
£9.52 ex VAT
£11.42 inc VAT
This USB 3.0 memory card reader provides a fast, easy way to access and edit photos and videos on your SD and microSD cards, wherever you go. Compact and portable, you can use this USB memory card reader/writer with a laptop, tablet, smartphone or desktop computer that has a USB-C or USB-A port.
  • Increase workflow efficiency
    Ideal for photographers, videographers and other creative professionals, the USB memory card reader helps to increase workflow efficiency. When you are out on assignment capturing images and video on your DSLR or video camera, use the card reader to instantly review, share or edit content. When out in the field or traveling, immediately import your photos and videos to access, browse, edit and back up content to your USB Type-C or USB-A smartphone, tablet, laptop or desktop computer.
  • Easy to use
    This memory card reader gives you easy read/write access to SD and microSD cards. With its convenient plug-and-play functionality, the card reader is simple to use. One end plugs directly into the USB-C port of your laptop or other device, while the other end works with USB-A devices. The two memory card slots are hot swappable.
  • Ultimate portability
    Compact and durable, the card reader provides a portable solution, tucking easily into your camera bag or laptop bag. Its versatile design enables the card reader to be used with either USB-C or USB-A devices. Removable end caps protect the ends of the card reader when not in use.
StarTech.com USB Memory Card Reader - USB 3.0 SD Card Reader - Compact - 5Gbps - USB Card Reader - MicroSD USB Adapter (SDMSDRWU3AC) - card reader - USB 3.0/USB-C
Card reader - external
Supported Memory Cards
MultiMediaCard, SD Memory Card, microSD, SDHC Memory Card, microSDHC, SDXC Memory Card, microSDXC
Host Interface
USB 3.0/USB-C
Memory card up to 2TB
Host Interface
USB 3.0/USB-C
2 cm
7.8 cm
1.1 cm
11.8 g
Memory Card
(max)
Required Ports
1 x 24 pin USB-C , 1 x 9 pin USB Type A
2 end caps
FCC, RoHS
CX8Z StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £38.96
CX8Z StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £48.45
CX8Z StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £30.59
CX8Z StarTech.com 4-Port USB 3 Hub + 2.4A DCP In Stock £44.32
CX8Z StarTech.com Flash Card Reader - USB-C In Stock £25.42
CX8Z StarTech.com CFast Card Reader - USB 3.0 In Stock £22.38
CX8Z StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £29.79
CX8Z StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £41.30
CX8Z StarTech.com CFast Card Reader - USB-C In Stock £28.39
Supported Formats: microSDHC
Supported Formats: SDHC Memory Card
Supported Formats: MultiMediaCard
Supported Formats: SD Memory Card
Supported Formats: microSDXC
Supported Formats: SDXC Memory Card
Interface: USB 3.0/USB-C
