StarTech.com USB 3.0 Multi Media Flash Memory Card Reader
Quicklinx: 7W8HWS00 Mfr#: FCREADHCU3
£24.25 ex VAT
£29.10 inc VAT
Add the Ability to Use Multiple Types of Flash Memory Cards, Including CompactFlash?, SecureDigital? and MemoryStick? Cards. The FCREADHCU3 USB 3.0 Card Reader enables easy read/write access to a variety of popular flash memory card formats/types (CompactFlash?, Secure Digital?, Memory Stick?) in a single unit, over a high speed USB 3.0 connection. Using a connection over USB 3.0, which is up to 10 times faster than the USB 2.0 standard, makes transferring large data files much quicker; it (USB 3.0) is still backward compatible with USB 2.0 however, ensuring compatibility with older systems. This compact and lightweight external card reader offers a portable, convenient solution for accessing many different types of Flash Memory/Media cards and is easy to use, with no driver or software installation required.
StarTech.com USB 3.0 Multi Media Flash Memory Card Reader - Card reader (Multi-Format) - USB 3.0 - FCREADHCU3 - card reader - USB 3.0
Card reader - external
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, miniSD, RS-MMC, microSD, SDHC Memory Card, miniSDHC, microSDHC, Memory Stick PRO-HG Duo, SDXC Memory Card, microSDXC
Host Interface
USB 3.0
Power indicator
Host Interface
USB 3.0
Power indicator
5.9 cm
8.6 cm
2.1 cm
69 g
Memory Card
(max)
Required Ports
1 x 9 pin USB Type B
Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
FCC, RoHS
7W8H StarTech.com Flash Card Reader - USB-C In Stock £25.42
7W8H StarTech.com USB Multi-Media Card Reader In Stock £16.82
Supported Formats: Memory Stick PRO-HG Duo
Supported Formats: SDHC Memory Card
Supported Formats: CompactFlash Card type I
Supported Formats: Memory Stick Duo
Supported Formats: Memory Stick PRO Duo
Supported Formats: MultiMediaCard
Supported Formats: SD Memory Card
Supported Formats: CompactFlash Card type II
Supported Formats: RS-MMC
Supported Formats: microSD
Supported Formats: miniSDHC
Supported Formats: microSDHC
Supported Formats: SDXC Memory Card
Supported Formats: microSDXC
Interface: USB 3.0
