StarTech.com USB 3.0 Multi-Card Reader
Quicklinx: BM07WS00 Mfr#: 35FCREADBU3
11 in stock
£27.82 ex VAT
£33.38 inc VAT
Turn a 3.5" internal bay on your computer into a fast and versatile memory card reader - for SD, Micro SD, CF, Memory Stick and more. Now, you can transfer large files like photos and 4K video, back up files or offload data, to and from your memory cards, at speeds like never before. This USB 3.0 internal multi-card reader supports UHS-II to greatly enhance your file transfer rates. The card reader supports High Capacity/eXtended Capacity cards and most standard memory cards, including SecureDigital, Compact Flash, Memory Stick and micro SD cards. It also enables concurrent downloads. Fast speed and wide compatibility make this multi-card reader an ideal solution for photo kiosks or photo labs, and desktop computers.
The card reader is USB powered so there's no external power or battery required. Front USB access lets you connect USB devices easily.
With support of UHS-II cards, the multi-card reader lets you transfer large files to and from your memory cards at speeds of up to 312 Mbps, saving you time on data offloads of 4K, full HD and 3D videos.
Using a USB 3.0 connection, also known as USB 3.1 Gen 1, the card reader supports fast file transfer speeds of up to 5 Gbps, enabling you to leverage the increased capabilities of new, higher performing memory cards.
Save time with concurrent downloads. This 5-slot multi-card reader design allows you to access up to four memory cards simultaneously for fast and easy file transfers.
The USB 3.0 multi-card reader works with most standard memory cards, including: Secure Digital (Standard Card, HC card, XC card, MMC, Mini SD with adapter); Micro SD (Standard card, HC card, XC card); Compact Flash (CF I or II, CF 6.0); Memory Stick (Standard, Pro, Duo, Pro Duo, Pro-HG, XC, Micro MS with adapter).
StarTech.com USB 3.0 Internal Multi-Card Reader w/ UHS-II -SD/MicroSD/MS/CF - card reader - USB 3.0
Card reader - internal
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, miniSD, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, SDXC Memory Card, Memory Stick XC, Memory Stick PRO-HG
Host Interface
USB 3.0
Required Bay
3.5" internal
LED indicator
Host Interface
USB 3.0
Required Bay
3.5" internal
LED indicator
20 cm
11.8 cm
2.4 cm
250 g
Additional Ports
1 x USB 3.0
Required Ports
1 x 20 pin USB 3.0 header
Mounting kit
FCC, RoHS
BM07 StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £4.84
BM07 StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F In Stock £3.07
BM07 StarTech.com 6in USB 3.0 Extension Cable In Stock £4.05
Supported Formats: CompactFlash Card type I
Supported Formats: CompactFlash Card type II
Supported Formats: Memory Stick
Supported Formats: Memory Stick Duo
Supported Formats: Memory Stick Micro (M2)
Supported Formats: Memory Stick PRO
Supported Formats: Memory Stick PRO Duo
Supported Formats: Memory Stick PRO-HG
Supported Formats: Memory Stick XC
Supported Formats: microSD
Supported Formats: microSDHC
Supported Formats: miniSD
Supported Formats: MultiMediaCard
Supported Formats: SD Memory Card
Supported Formats: SDHC Memory Card
Supported Formats: SDXC Memory Card
Interface: USB 3.0
Price Range Ex VAT: 0 - 50
