The 35BAYUSB3S4 3.5-inch Front Bay to 4-Port USB 3.0 Panel Hub turns any available 3.5-inch computer case front bay into a 4-Port USB 3.0 hub.
Using only a single USB connection, this front panel hub adds four easily accessible USB ports to the front of your computer case through a 3.5-inch bay, or through a 5.25-inch bay using the optional Front Bay Bracket Adapter (BRACKETFDBK) accessory. Each of the added ports is compliant with the USB 3.0 standard which supports up to 5 Gbps of bandwidth (10x faster than the USB 2.0 standard) and up to 900mA of power.
Accessorize with the PEXUSB3S11 PCI Express card to provide an internal USB 3.0 port, so as to keep the external ports free for external devices. Backed by a StarTech.com 2-year warranty and free lifetime technical support.
The StarTech.com Advantage
Connect up to four USB 3.0/2.0/1.x devices simultaneously, through your computers front 3.5" bay
SuperSpeed USB 3.0 supports up to 5 Gbps of bandwidth and up to 900mA of power per port to support faster and more powerful devices
Four front accessible USB type-A ports
Fits into any 3.5" computer case front bay
SuperSpeed USB 3.0 compliant, supporting data transfer rates up to 5 Gbps
Backward compatible with USB 2.0 and USB 1.0/1.1 specifications and devices
Provides up to 900mA of power per port
USB Link LED indicator for each port
Applications
Expand your system's USB 3.0 capabilities with additional ports for connecting high speed external storage devices
Add easier to access USB ports to the front of a computer system instead of the rear
Make use of an internal USB port and unused 3.5" front bay to increase the system's expandability
- StarTech.com USB 3.0 Front Panel 4 Port Hub - 3.5in or 5.25in Bay - Front Internal 3.5 USB 3 Hub (35BAYUSB3S4) - hub - 4 ports - plug-in module
- Hub - 4 ports
- Enclosure Type
- Plug-in module
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- 10 cm x 12 cm x 2.5 cm
- 160 g
- Black
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- 2-year warranty
- Designed For
- P/N: USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
- Hub - 4 ports
- Enclosure Type
- Plug-in module
- Subtype
- USB
- Ports
- Status Indicators
- Link/activity
- 4 x USB 3.0 Type A , 1 x 15 pin Serial ATA power , 1 x USB 3.0
- Black
- OS Required
- 10 cm
- 12 cm
- 2.5 cm
- 160 g
- Limited warranty - 2 years
- 5 °C
- 50 °C
- 20 - 80%
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 20 - 80%
- Designed For
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £5.06 |
StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter | In Stock | £5.88 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £6.34 |
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £27.76 |
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £101.41 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £6.34 |
