Add a compact external memory card reader to any computer with a USB 3.0 port. The FCREADMICRO3 USB 3.0 Multi-media Card Reader offers quick access to the most popular flash card formats, from any computer with a USB port (optimal performance with 3.0, backward compatible with USB 2.0).
Suitable for quickly accessing memory cards of virtually any portable media device (e.g. digital cameras, MP3 players, etc.), this versatile media card reader supports the most popular card types, including: Secure Digital (SD), Multi-Media Card (MMC), Mini-SD, Micro-SD/SDHC (T-flash), SDHC, SDXC, RS-MMC, Mobile-MMC and MMC-micro, Memory Stick (MS), Memory Stick PRO (MS-PRO), MS Duo, MS-PRO Duo, Memory Stick XC, Micro-MS (M2), MSPRO-HG Duo 8-bit mode.
An ideal Laptop or Desktop accessory, this pocket-sized memory card reader is lightweight, portable.
- StarTech.com USB 3.0 Multimedia Memory Card Reader - Portable SDHC MicroSD Card Reader - External USB Flash Card Reader (FCREADMICRO3) - card reader - USB 3.0
- Product Type
- Card reader - external
- Supported Memory Cards
- Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, miniSD, RS-MMC, MultiMediaCardmobile, microSD, MultiMediaCardmicro, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, Memory Stick PRO-HG Duo, SDXC Memory Card, Memory Stick XC
- Host Interface
- USB 3.0
- Black
- 2-year warranty
- Product Type
- Host Interface
- USB 3.0
- Black
- 2.3 cm
- 7.2 cm
- 1.5 cm
- 15 g
Memory Card
- Capacity
- (max)
- Required Ports
- 1 x 9 pin USB Type B
- OS Required
- Microsoft Windows 2000, Apple MacOS X, Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- FCC, RoHS
- Limited warranty - 2 years
StarTech.com 4 Port Black USB 2.0 Hub | In Stock | £18.58 |
StarTech.com 5 ft Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F | In Stock | £12.03 |
StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 | In Stock | £39.12 |
StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £7.17 |
StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.67 |
StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black | In Stock | £19.88 |
StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - White | In Stock | £19.88 |
StarTech.com 3.5in Front Bay 22-in-1 USB 2.0 Internal Multi Media Memory Card Reader - Black | In Stock | £12.02 |
StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable | In Stock | £21.37 |
StarTech.com USB Multi-Media Card Reader | In Stock | £17.64 |
