StarTech.com USB 3.0 eSATA Hard Drive Enclosure - Trayless 3.5" SATA III HDD Enclosure - Black
Quicklinx: 93JXWS00 Mfr#: S3510BMU33ET
  • Windows 8 (32/64 bits)
Easily connect and hot swap 3.5in SATA III hard drives, through either eSATA or UASP-supported USB 3.0. The S3510BMU33ET Removable Hard Drive Enclosure lets you connect a 3.5" SATA hard drive through an available USB 3.0 or eSATA port, with a tray-less design that makes hot-swapping easy.
For fast performance and efficient data transfers, when connected through eSATA, the enclosure supports full SATA III transfer speeds - up to 6 Gbps. For universal compatibility, the enclosure can be connected through USB 3.0 with transfer speeds up 5 Gbps plus support for UASP, which supports performance up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller to utilize the full potential of your SATA III hard drives. See the UASP testing results below for further details.
The HDD enclosure offers a versatile solution for increasing the storage/backup capabilities of your computer, with support for hard drives at capacities of up to 4TB, and the ability to easily hot-swap between drives. Plus, to maximize both durability and reliability, the enclosure features high-quality aluminum construction.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com USB 3.0 / eSATA 3.5" SATA III Hard Drive Enclosure w/ UASP - storage enclosure - SATA 6Gb/s - eSATA 6Gb/s, USB 3.0
Storage enclosure - external
Bus Type
Expansion Bays
1 x internal - 3.5"
Hard Drive Form Factor Compatibility
3.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
Max Storage Devices Qty
1
Power Source
Included AC adapter
Apple MacOS, Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits)
18 cm x 22.5 cm x 11.5 cm
880 g
P/N: SATDUP11IMG
3.5"
Host Bus
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
1
ASMedia ASM1051E
Bays
1 x internal - 3.5"
1 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 9 pin USB Type A , 1 x eSATA 6Gb/s - 7 pin external Serial ATA
1 x USB cable - external , 1 x eSATA cable - external
Storage tray, LED indicator
FCC, RoHS
Power Source
Included AC adapter
Power adapter
18 cm
22.5 cm
11.5 cm
880 g
-20 °C
70 °C
P/N: SATDUP11IMG
93JX StarTech.com 6 ft Shielded External eSATA Cable M/M In Stock £9.58
