StarTech.com USB 3.0 eSATA Hard Drive Docking Station with Cooling Fan
Quicklinx: 7P27WS00 Mfr#: SATDOCKU3FGB
Dock your 2.5in or 3.5in SATA Hard Drive over USB 3.0 or eSATA, with the added benefit of a built-in Cooling Fan. The SATDOCKU3SEF Hard Drive Docking Station (eSATA/USB 3.0 to SATA) delivers quick and easy access to a 2.5in or 3.5in SATA hard disk drive (HDD) or solid state drive (SSD) through either eSATA or USB connectivity, making it compatible with almost any system. Large capacity drives (tested with up to 4TB 3.5" and 1TB 2.5" drives) can be used to greatly enhance your computer''s storage/backup capabilities.
The docking station features a built-in 80mm cooling fan that provides increased reliability and lifespan to HDDs by keeping the drives cooler. The variable fan speed control allows for on-the-fly adjustments for any type of HDD, or to balance cooling with noise. The HDD dock will also power down SATA drives after a period of inactivity (USB mode only) or when the PC is turned off, to help reduce power consumption and noise when not being accessed.
The docking station supports full eSATA data transfer rates of up to 3 Gbps, and USB 3.0 transfer rates up to 5 Gbps while backward compatible with USB 2.0 system transfer rates of up to 480 Mbps.
For an even more versatile storage solution, this eSATA/USB 3.0 HDD docking station can be used with the SATA to IDE hard drive adapter (SAT2IDEADP) enabling you to use 2.5in or 3.5in IDE hard drives with the dock.
StarTech.com USB 3.0 eSATA Hard Drive Docking Station with Cooling Fan - HDD docking station - eSATA - USB 3.0
HDD docking station - external
Bays
1
Bus Type
USB 3.0
Expansion Bays
1 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
eSATA
Data Transfer Rate
5 GBps
Supported Devices
Hard drive
Product Material
Plastic
Power Source
Included AC adapter
AC 120/230 V
Linux, Microsoft Windows 2000, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
9.2 cm x 13 cm x 12.7 cm
0.5 kg
Bays
1
2.5", 3.5"
Host Bus
USB 3.0
Product Material
Plastic
Storage Controller
eSATA
Data Transfer Rate
5 GBps
Supported Devices
Hard drive
Bays
1 x eSATA - SATA
1 x USB 3.0 - 9 pin USB Type B
Tested with up to 4TB 5400 RPM 3.5” hard drives, tested with up to 1TB 5400 RPM 2.5” hard drives
FCC, RoHS
Power Source
Included AC adapter
Power adapter
AC 120/230 V
9.2 cm
13 cm
12.7 cm
0.5 kg
5 °C
80 °C
8 - 90%
