StarTech.com USB 3.0 Data Transfer Cable
Quicklinx: BM06WS00 Mfr#: USB3LINK
Length: 1.85m
Hurry, only 3 left in stock!
£35.50 ex VAT
£42.60 inc VAT
Quickly and easily transfer all of your Windows or Mac files to your new computer. Here's an easy way to transfer files from your old computer to your new one. This data transfer cable lets you move files quickly over USB 3.0, and works with both Mac and Windows.
The transfer cable saves you time and effort when you're upgrading to a new computer. You can transfer your files and settings quickly over USB 3.0, also known as USB 3.1 Gen 1, with file transfer speeds up to 5 Gbps. Plus, there are no additional drivers to install when connecting your computers, because the necessary software is stored on the cable.
The data transfer cable supports a wide range of operating systems, working with Windows and Mac. The USB 3.0 transfer cable lets you transfer files between two computers including Windows to Windows, Windows to Mac, Mac to Windows, and even Mac to Mac.
The data transfer cable is compatible with Windows Easy Transfer software for migrating to newer versions of Windows, up to Windows 8. Plus, the built-in PCLinq software also allows file transfers in any direction between compatible operating systems, including Windows 10.
The USB3LINK data transfer cable comes in a convenient 2 m (6 ft.) length.
  • Save time setting up your new computer
  • Wide compatibility with Mac and PC
    The data transfer cable supports a wide range of operating systems, working with Windows and Mac. The USB 3.0 transfer cable lets you transfer files between two computers including Windows to Windows, Windows to Mac, Mac to Windows, and even Mac to Mac. The data transfer cable is compatible with Windows Easy Transfer software for migrating to newer versions of Windows, up to Windows 8. Plus, the built-in PCLinq software also allows file transfers in any direction between compatible operating systems, including Windows 10. The USB3LINK data transfer cable comes in a convenient 2 m (6 ft.) length, and is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com USB 3.0 Data Transfer Cable for Windows & Mac - 2m (6ft) - direct connect adapter - USB 3.0 - USB 3.0
Direct connect adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
USB 3.0
Length
1.85 m
77 g
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
Prolific PL-27A1
USB 1.1, USB 2.0, USB 3.0
Microsoft Windows Vista / 7 / 8 / 8.1, Windows 10 (32/64 bits), Apple MacOS X 10.7.5 - 10.10
External
SuperSpeed USB 3.0
Ports
USB 3.0
Wired
USB, USB 2.0, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
Status Indicators
Link/activity
Processor / Memory
Prolific PL-27A1
1 x USB 3.0 - 9 pin USB Type A - male
MTBF
500,000 hour(s)
FCC, RoHS
Software Included
PC-Linq
Length
1.85 m
77 g
50 °C
5 - 85%
BM06 StarTech.com USB C to USB Transfer Cable - 2m In Stock £26.80
Length: 1.85m
