StarTech.com USB 3.0 / eSATA Dual Hard Drive Docking Station with UASP for 2.5/3.5in SATA SSD / HDD
Quicklinx: 9J3PWS00 Mfr#: SDOCK2U33EB
Type: Storage controller
HD Size: 2.5, 3.5
Power Supply: [N/A]
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
11 In Stock
£67.18 ex VAT
£80.61 inc VAT
Easily connect and swap two 2.5 or 3.5in SATA III drives through eSATA or USB 3.0. The SDOCK2U33EB Dual 2.5/3.5" SATA hard drive docking station lets you dock and swap hard drives from your desktop or laptop computer simultaneously using a single eSATA or USB port.
For fast performance and efficient data transfers when connected through eSATA, the docking station supports full SATA III transfer speeds - up to 6 Gbps. For universal compatibility, the dock can be connected through USB 3.0 with transfer speeds up 5 Gbps plus support for UASP, which supports performance up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller to utilize the full potential of your SATA III hard drives.
The hard drive docking station supports the fastest drive technologies including SATA III (6 Gbps), hybrid drives and solid state drives (SSD), ensuring you can save time by getting the most out of your drive performance.
Extend the value of this hard drive docking station further with the addition of the SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5 or 3.5in. IDE hard drive into a SATA hard drive dock.
To ensure compatibility with your computer system, the SDOCK2U33EB supports all of the leading operating systems, including: Microsoft Windows (8/7/Vista/XP/Server 2008/Server 2003), Apple OSX (10.9/10.8/10.7/10.6), Linux, and Google Chrome OS.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
  • Efficient data transfer
    The docking station provides data transfer rates of 6 Gbit/s through both USB 3.0 and eSATA interfaces, ensuring quick access to files.
  • Hot-swap compatibility
    Features hot-swap capability that enables users to connect and disconnect drives without needing to power down the device, promoting convenience during data management.
  • Advanced drive support
    Supports a total of 2 storage devices simultaneously with compatibility for 2.5-inch and 3.5-inch hard drives, suitable for various storage needs.
  • Robust environmental performance
    Designed to operate effectively within a temperature range of 5°C to 35°C and humidity levels from 20% to 80%, ensuring consistent performance in different conditions.
StarTech.com Dual-Bay USB 3.0 eSATA to SATA Hard Drive Docking Station, USB Hard Drive Dock, External 2.53.5 SATA IIIIII, SSDHDD Docking Station, Hot-Swap Hard Drive Bays - Top-Loading - storage controller - SATA 6Gb/s - eSATA 6Gb/s, USB 3.0
Storage controller - external
Bus Type
Expansion Bays
2 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
2
AC 120/230 V
Linux, Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Google Chrome OS, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.6 - 10.9
14.8 cm x 13.2 cm x 7 cm
532 g
P/N: SVA12M5NA
2.5", 3.5"
Host Bus
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
2
JMS562
Bays
2 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 9 pin USB Type B , 1 x eSATA 6Gb/s - 7 pin external Serial ATA
1 x USB 3.0 cable - external , 1 x eSATA cable - external
Tested with up to 4TB 7200 RPM 3.5" hard drives, tested with up to 2TB 5400 RPM 2.5" hard drives
FCC, RoHS
Power adapter
AC 120/230 V
14.8 cm
13.2 cm
7 cm
532 g
5 °C
35 °C
20 - 80%
P/N: SVA12M5NA
9J3P StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.33
9J3P StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.76
9J3P StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.65
9J3P StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.36
9J3P StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.48
9J3P StarTech.com USB 3.0 / eSATA Dual Hard Drive Docking Station with UASP for 2.5/3.5in SATA SSD / HDD In Stock £67.18
9J3P StarTech.com DC Power Adapter - 12V, 5A In Stock £44.06
HD Size: 2.5
HD Size: 3.5
Power Supply: [N/A]
