StarTech.com USB 3.0 / eSATA 8-Bay Hot-Swap 2.5/3.5" SATA III Hard Drive Enclosure with UASP
Quicklinx: 9PRZWS00 Mfr#: S358BU33ERM
£282.19 ex VAT
£338.62 inc VAT
Connect eight hot-swappable 2.5/3.5" SATA III hard drives to your computer externally through USB 3.0 with UASP or eSATA. The S358BU33ERM 8-bay removable hard drive enclosure lets you access eight individual 2.5" or 3.5" hard drives simultaneously using a single eSATA or USB port.
For fast performance and efficient data transfers when connected through eSATA, the HDD enclosure supports full SATA III transfer speeds - up to 6 Gbps. For universal compatibility, the enclosure can be connected through USB 3.0 with transfer speeds up 5 Gbps plus support for UASP, which supports performance up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller to utilize the full potential of your SATA III hard drives.
The HDD enclosure supports the fastest drive technologies including SATA III (6 Gbps), hybrid drives and solid state drives (SSD), helping save you time through optimized performance from your external storage devices.
To help protect your drives the HDD/SSD enclosure has a built-in fan that keeps your drives running at optimal temperatures. Plus, the metal drive trays ensure maximum heat dissipation.
To ensure compatibility with your computer system, the drive enclosure is OS independent. Please note that in order to access multiple drives, the enclosure requires that your host device supports port multiplier. For desktop computers without port multiplier capability, StarTech.com offers the PEXESATA2" text="2 Port PCI Express eSATA Controller Card (PEXESATA2).
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com USB 3.0 / eSATA 8-Bay Hot-Swap 2.5/3.5" SATA III Hard Drive Enclosure with UASP - storage enclosure
Storage enclosure
0 (installed) / 8 (max)
Supported Drives
SATA-600
Storage Controller
(eSATA-600)
AC 120/230 V
Storage enclosure
Enclosure Colour
Chassis
0
Supported Devices / Modules Qty
8
Supported Drives
SATA-600
Storage Controller
(USB 3.0)
Interface Type
eSATA-600
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5" / 3.5" shared
8 x eSATA 6Gb/s
1 x eSATA cable , 1 x USB 3.0 cable , 1 x power cable
FCC, RoHS
eSATA bracket
Internal power supply
AC 120/230 V
9PRZ StarTech.com 3 ft Shielded External eSATA Cable M/M In Stock £7.02
9PRZ StarTech.com 6 ft Shielded External eSATA Cable M/M In Stock £9.22
9PRZ StarTech.com 2 Port SATA 6 Gbps PCI Express eSATA Controller Card In Stock £21.88
9PRZ StarTech.com 2 Port PCI Express SATA 6 Gbps eSATA Controller Card - 2 Int/2 Ext In Stock £27.13
9PRZ StarTech.com 4 Port PCI Express 2.0 SATA III 6Gbps RAID Controller Card with HyperDuo SSD Tiering In Stock £56.87
9PRZ StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black In Stock £62.49
9PRZ StarTech.com USB 3.0 / eSATA Dual-Bay Trayless 3.5" SATA III Hard Drive Enclosure with UASP In Stock £94.24
9PRZ StarTech.com USB 3.0 Dual 3.5in SATA III Hard Drive RAID Enclosure with Fast Charge USB Hub & UASP In Stock £91.38
9PRZ StarTech.com USB 3.0 / eSATA 5-Bay Hot-Swap 2.5/3.5" SATA III Hard Drive Enclosure with UASP In Stock £150.61
Price Range Ex VAT: 150 - 300
