StarTech.com USB 2 to Fiber Optic Converter
Quicklinx: DFR5WS00 Mfr#: US100A20SFP
Wired / Wireless: Wired
Protocol: Fast Ethernet
Form Factor: External
Type: Network adapter
£98.31 ex VAT
£117.97 inc VAT
Connect to a 100Mbps Ethernet network through your laptop's USB-A port using the 100Mbps SFP of your choice. This USB to fiber-optic converter lets you utilize the USB 2.0 (Type-A) port on your laptop or tablet to provide a secure fiber network connection. Windows and Mac compatible, the network adapter provides a 100Mbps Ethernet optical network connection for portable laptops or tablets, or systems without expansion slots.
A flexible solution with an open SFP slot
The open SFP slot enables you to use your preferred SFP transceiver module to meet your networking needs - use an SFP with your desired wavelength, distance, connection type to achieve an efficient network solution. (SFP sold separately.)
Secure fiber-to-the-desk connectivity
This USB to fiber converter provides reliable connectivity while protecting your network from problems with electronic interference - a common issue with copper Ethernet networks. Fiber-to-the-desk connectivity (FTTD) maximizes network security, reducing the risk of data leaks of sensitive information, without compromising network speed and reliability.
Easy portability
Compact and portable, this USB 2.0 to fiber-optic converter is powered directly from the USB port, making it easy to connect when you're on the go.
Plug and play
Get up and running quickly. The USB to fiber-optic converter supports certified drivers for Windows and Linux . When you plug the adapter into a USB port, you simply install the drivers and the adapter is ready to transmit over a fiber network.
The US100A20SFP is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Secure connectivity
    This USB to fiber converter provides reliable connectivity while protecting your network from problems with electronic interference.
  • Easy portability
    Compact and portable, this converter is powered directly from the USB port, making it easy to connect when you're on the go.
StarTech.com USB to Fiber Optic Converter - Open SFP - 100Mbps - Windows & Linux - USB to Ethernet Adapter - USB Network Adapter (US100A20SFP) - network adapter - USB 2.0 - SFP (mini-GBIC) x 1
Network adapter
External
Interface (Bus) Type
USB 2.0
Ports
SFP (mini-GBIC) x 1
5.5 cm x 26 cm x 2 cm
100 g
Cabling Type
Ethernet 100Base-X
100Mb LAN
Data Transfer Rate
100 Mbps
ASIX AX88772C
Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 3.5 to 4.11.x LTS versions
Network adapter
External
USB 2.0
Ports
SFP (mini-GBIC) x 1
Wired
Cabling Type
Ethernet 100Base-X
Fast Ethernet
Data Transfer Rate
100 Mbps
Status Indicators
Power, link/activity
WOL, USB powered, plastic housing
Processor / Memory
ASIX AX88772C
1 x 100Base-X - SFP (mini-GBIC) - female
Plug and Play, FCC, RoHS, MSA
5.5 cm
26 cm
2 cm
100 g
60 °C
5 - 90%
DFR5 StarTech.com 100Base-LX SFP - SM LC- 10 km In Stock £40.10
DFR5 StarTech.com USB 3 Fiber Converter Open SFP In Stock £162.25
DFR5 StarTech.com USB 2.0 to Fiber Converter In Stock £134.93
DFR5 StarTech.com USB C to Fiber Optic Converter In Stock £189.66
