StarTech.com USB 2.0 to 10/100 Mbps Ethernet Network Adapter Dongle
Quicklinx: 9KZSWS00 Mfr#: USB2100
Wired / Wireless: Wired
Protocol: Fast Ethernet, Ethernet
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
16 In Stock
£14.71 ex VAT
£17.65 inc VAT
Add a 10/100Mbps Ethernet port to your laptop or desktop computer through USB. The USB2100 USB 2.0 to 10/100 Mbps Network Adapter lets you add a Fast Ethernet port to your laptop or desktop computer through USB.
This compact USB network adapter offers a dongle design with a built-in cable to avoid cramped connections, making it a perfect solution for adding wired Ethernet connectivity to your desktop without opening the case, or to replace a failed onboard network adapter on your laptop system.
Providing half or full-duplex operation, this USB 2.0 Ethernet adapter supports data transfer rates of up to 200 Mbps. The adapter also supports features such as Wake-on-LAN (WoL) and VLAN tagging for added flexibility.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Mac Address Pass-Through Utility : To improve network security. •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com USB 2.0 to 10/100 Mbps Ethernet Network Adapter Dongle - USB Network Adapter - USB 2.0 Fast Ethernet Adapter - USB NIC (USB2100) - network adapter - USB 2.0 - 10/100 Ethernet
Network adapter
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet
2.2 cm x 6.6 cm x 1.7 cm
49 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
ASIX AX88772C
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q
Microsoft Windows Server 2003, Linux 2.6.x or later, Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
Network adapter
External
USB 2.0
Ports
10/100 Ethernet
Wired
Cabling Type
Ethernet, Fast Ethernet
Data Transfer Rate
100 Mbps
Status Indicators
Link OK, link/activity
Full duplex capability, WOL, auto-uplink (auto MDI/MDI-X), USB powered, tagged VLAN
Processor / Memory
ASIX AX88772C
1 x 100Base-TX - RJ-45 - female
1 x USB cable (integrated) - 15 cm
FCC, RoHS
Software Included
Drivers & Utilities
2.2 cm
6.6 cm
1.7 cm
49 g
10 °C
10 - 90%
9KZS StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps In Stock £20.93
9KZS StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black In Stock £30.45
9KZS StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - White In Stock £28.24
Protocol: Ethernet
Compatibility: Mac
Compatibility: PC
