Add a 10/100Mbps Ethernet port to your laptop or desktop computer through USB. The USB2100 USB 2.0 to 10/100 Mbps Network Adapter lets you add a Fast Ethernet port to your laptop or desktop computer through USB.
This compact USB network adapter offers a dongle design with a built-in cable to avoid cramped connections, making it a perfect solution for adding wired Ethernet connectivity to your desktop without opening the case, or to replace a failed onboard network adapter on your laptop system.
Providing half or full-duplex operation, this USB 2.0 Ethernet adapter supports data transfer rates of up to 200 Mbps. The adapter also supports features such as Wake-on-LAN (WoL) and VLAN tagging for added flexibility.
- StarTech.com USB 2.0 to 10/100 Mbps Ethernet Network Adapter Dongle - USB Network Adapter - USB 2.0 Fast Ethernet Adapter - USB NIC (USB2100) - network adapter - USB 2.0 - 10/100 Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- 10/100 Ethernet
- 2.2 cm x 6.6 cm x 1.7 cm
- 49 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX
- Data Link Protocol
- 10Mb LAN, 100Mb LAN
- Data Transfer Rate
- 100 Mbps
- Processor
- ASIX AX88772C
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q
- Black
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14
- 2-year warranty
- Network adapter
- Form Factor
- External
- USB 2.0
- Ports
- 10/100 Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet
- 100 Mbps
- Status Indicators
- Link OK, link/activity
- Full duplex capability, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), USB powered, tagged VLAN
Processor / Memory
- Processor
- ASIX AX88772C
- 1 x 100Base-TX - RJ-45 - female
- Cables Included
- 1 x USB cable (integrated) - 15 cm
- FCC, RoHS
- Black
- Software Included
- Drivers & Utilities
- OS Required
- 2.2 cm
- 6.6 cm
- 1.7 cm
- 49 g
- Limited warranty - 2 years
- 10 °C
- 40 °C
- 10 - 90%
