StarTech.com USB 2.0 Multi Card Reader
Customer rating: 5.0* (Write a review)
Quicklinx: 4RXFWS00 Mfr#: FCREADHC
Add a 14-in-1 high capacity external memory card reader to any USB computer. This USB 2.0 14-in-1 media memory card reader offers fast and convenient access to the most popular media/memory card formats including SD, Compact Flash, MMC, Memory Stick and IBM Micro Drive as well as SDHC cards for applications requiring high capacity storage.
Simply connect the card reader to a USB 2.0 port on the host computer, then insert the memory card into the reader for read/write access to the contents of the media/memory card. The card reader supports full hi-speed transfer rates of up to 480Mbps using a USB 2.0 connection and is backward compatible with USB 1.1, ensuring compatibility with virtually any USB capable computer.
StarTech.com 14-in-1 USB 2.0 High Capacity Silver Multi Media Memory Card Reader - card reader - USB 2.0
Card reader - external
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, SmartMedia Card, Memory Stick Duo, Memory Stick PRO Duo, miniSD, RS-MMC, SDHC Memory Card
Host Interface
USB 2.0
P/N: USB1000IP
Host Interface
USB 2.0
Memory Card
(max)
Required Ports
1
Apple MacOS X 10.1.2 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista
USB cable
Software Included
Drivers & Utilities
FCC, RoHS
P/N: USB1000IP
Customer reviews
Write a review for the StarTech.com USB 2.0 Multi Card Reader here!
a good one
Reviewed by Peng. Review Posted 09/07/2008
Compact and stylish, easy to use. Works fine with high capacity cards and the transfer rate is faster than my build-in card reader with the laptop. Very good value of money, recommonded!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
good but not perfect
Reviewed by John. Review Posted 18/04/2009
Pros:
1. Lots of card slots;
2. Very Cheap;
3. Very fast
4. Easy to use - just plug it in.
Only 3 minor probs:
1. The build quality whilst solid, feels cheap and the cards are not a snug fit, you may have to wiggle them a little to get them to fit.
2. Card eject instructions are wrong, they will eject the card reader; instead go to My Computer, right click on the drive and select eject.
3. My computer will not boot-up if the reader is plugged in (it doesn't even get the bios splash screen) - if you get this prob just unplug it and plug back in when Windows has loaded - easy.
  • Overall 4*
  • Ease of use 4*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
