StarTech.com USB 2.0 HD PVR Gaming and Video Capture Device – 1080p HDMI / Component
Quicklinx: 8Y6SWS00 Mfr#: USB2HDCAP
  • Windows 8 (32/64 bits)
Capture a High-Definition HDMI or Component Video source to your PC. The USB2HDCAP USB 2.0 HD Video Capture Device lets you record high-definition (1080p) video and stereo audio from an HDMI, S-Video or Component source to your computer, through an available USB 2.0 port - the perfect solution for recording video game play, or home videos for editing and compiling.
This versatile USB capture device supports both NTSC and PAL systems, and includes an easy-to-use video capture software suite which lets you record video or take still screenshots and save them to your PC. The device also offers video pass-through, so you can watch the same source on an external display.
The capture device features on-board hardware H.264 encoding, which manages the video conversion process independently of your computer and in turn saves valuable system resources.
This USB video capture device will not record digitally encrypted content.
StarTech.com USB 2.0 HD PVR Gaming and Video Capture Device - video capture adapter - USB 2.0
Video capture adapter
Interface Type
USB 2.0
7.5 cm x 11.3 cm x 2.5 cm
170 g
Video Input
S-video input, S-video output, composite video input, composite video output, component video input, component video output, HD-PLC, HDMI input
Analogue Video Format
NTSC, PAL-M, PAL 60
Analogue video Signal
S-Video, composite video, component video
Digital Video Format
MPEG-4, H.264
Audio Input Support
Standard
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Interface Type
USB 2.0
7.5 cm
11.3 cm
2.5 cm
170 g
Video
Interface Type
NTSC, PAL-M, PAL 60
MPEG-4, H.264
Audio Input Support
Standard
1 x display / video - component video input - RCA x 3 , 1 x display / video - S-video input - 4 pin mini-DIN , 1 x audio - line-In - RCA x 2 , 1 x display / video - HDMI input - 19 pin HDMI Type A , 1 x display / video - component video output - RCA x 3 , 1 x display / video - S-video output - 4 pin mini-DIN , 1 x audio - line-out - RCA x 2 , 1 x display / video - HDMI output - 19 pin HDMI Type A
1 x USB 2.0 - 4 pin USB Type B
1 x USB cable - external , 1 x component video cable - external , 1 x audio cable - external
FCC, RoHS
Software Included
Drivers & Utilities
45 °C
20 - 80%
