StarTech.com USB 2.0 300 Mbps Mini Wireless-N Network Adapter - 802.11n 2T2R WiFi Adapter
Quicklinx: 9QB0WS00 Mfr#: USB300WN2X2C
Wired / Wireless: Wireless
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Form Factor: External
Compatibility: Mac, PC, Unix
Type: Network adapter
  • IEEE 802.11n
49 In Stock
£15.40 ex VAT
£18.48 inc VAT
Add high-speed Wireless-N connectivity to a desktop or laptop system through USB 2.0. The USB300WN2X2C USB Wireless Network Adapter lets you add 300 Mbps Wireless-N connectivity to your desktop or laptop system through USB 2.0. With a compact, lightweight design, the adapter is extremely portable, and is unobtrusive when connected to your system - you can even leave it connected to your laptop when in a carrying bag, without worrying about damaging the adapter or the host port while on the move.
The USB wireless adapter is capable of data transfer rates up to 300Mbps over a 2.4GHz 802.11n WiFi network (backward compatible with 802.11b/g), through a 2 Transmitter / 2 Receiver antenna design. The adapter also supports security options such as WEP, WPA or WPA2, as well as quick device connection through Wireless Protected Setup (WPS), for a reliable and secure connection.
StarTech.com USB 2.0 300 Mbps Mini Wireless-N Network Adapter - 802.11n 2T2R WiFi Adapter - USB Wireless Adapter - N300 Wireless NIC (USB300WN2X2C) - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
1.6 cm x 2.2 cm x 0.8 cm
2.5 g
802.11b/g/n
Data Transfer Rate
300 Gbps
Frequency Band
2.4 GHz
Realtek Semiconductor RTL8192EU
Microsoft Windows Server 2003, Linux 2.6.x, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14, Linux 4.4.x - 4.11.x LTS versions only
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
300 Gbps
Frequency Band
2.4 GHz
Status Indicators
Link/activity
WMM support
Aerial
Antenna
Internal
Antenna Qty
4
Processor / Memory
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA
Software Included
Drivers & Utilities
1.6 cm
2.2 cm
0.8 cm
2.5 g
10 - 90% (non-condensing)
9QB0 StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R In Stock £14.70
9QB0 StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R USB WiFi Adapter - White In Stock £3.35
9QB0 StarTech.com USB 2.0 AC600 Mini Dual Band Wireless-AC Network Adapter - 1T1R 802.11ac WiFi Adapter In Stock £27.59
9QB0 StarTech.com WiFi 6E USB Adapter/Dongle In Stock £65.15
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
