StarTech.com USB 2.0 300 Mbps Mini Wireless-N Network Adapter - 802.11n 2T2R WiFi Adapter
Quicklinx: 9QB0WS00 Mfr#: USB300WN2X2C
Wired / Wireless: Wireless
Protocol: IEEE 802.11b, IEEE 802.11n, IEEE 802.11g
Form Factor: External
Compatibility: Mac, PC, Unix
Type: Network adapter
  • IEEE 802.11n
44 In Stock
£15.03 ex VAT
£18.03 inc VAT
Add high-speed Wireless-N connectivity to a desktop or laptop system through USB 2.0. The USB300WN2X2C USB Wireless Network Adapter lets you add 300 Mbps Wireless-N connectivity to your desktop or laptop system through USB 2.0. With a compact, lightweight design, the adapter is extremely portable, and is unobtrusive when connected to your system - you can even leave it connected to your laptop when in a carrying bag, without worrying about damaging the adapter or the host port while on the move.
The USB wireless adapter is capable of data transfer rates up to 300Mbps over a 2.4GHz 802.11n WiFi network (backward compatible with 802.11b/g), through a 2 Transmitter / 2 Receiver antenna design. The adapter also supports security options such as WEP, WPA or WPA2, as well as quick device connection through Wireless Protected Setup (WPS), for a reliable and secure connection.
StarTech.com USB 2.0 300 Mbps Mini Wireless-N Network Adapter - 802.11n 2T2R WiFi Adapter - USB Wireless Adapter - N300 Wireless NIC (USB300WN2X2C) - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
1.6 cm x 2.2 cm x 0.8 cm
2.5 g
802.11b/g/n
Data Transfer Rate
300 Gbps
Frequency Band
2.4 GHz
Realtek Semiconductor RTL8192EU
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Microsoft Windows Server 2003, Linux 2.6.x, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14, Linux 4.4.x - 4.11.x LTS versions only
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
300 Gbps
Frequency Band
2.4 GHz
Status Indicators
Link/activity
WMM support
Aerial
Antenna
Internal
Antenna Qty
4
Processor / Memory
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA
Software Included
Drivers & Utilities
1.6 cm
2.2 cm
0.8 cm
2.5 g
10 - 90% (non-condensing)
9QB0 StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R In Stock £12.65
9QB0 StarTech.com USB 2.0 AC600 Mini Dual Band Wireless-AC Network Adapter - 1T1R 802.11ac WiFi Adapter In Stock £27.34
9QB0 StarTech.com WiFi 6E USB Adapter/Dongle In Stock £63.56
Protocol: IEEE 802.11n
Protocol: IEEE 802.11g
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
