Add high-speed Wireless-N connectivity to a desktop or laptop system through USB 2.0. The USB300WN2X2C USB Wireless Network Adapter lets you add 300 Mbps Wireless-N connectivity to your desktop or laptop system through USB 2.0. With a compact, lightweight design, the adapter is extremely portable, and is unobtrusive when connected to your system - you can even leave it connected to your laptop when in a carrying bag, without worrying about damaging the adapter or the host port while on the move.
The USB wireless adapter is capable of data transfer rates up to 300Mbps over a 2.4GHz 802.11n WiFi network (backward compatible with 802.11b/g), through a 2 Transmitter / 2 Receiver antenna design. The adapter also supports security options such as WEP, WPA or WPA2, as well as quick device connection through Wireless Protected Setup (WPS), for a reliable and secure connection.
- StarTech.com USB 2.0 300 Mbps Mini Wireless-N Network Adapter - 802.11n 2T2R WiFi Adapter - USB Wireless Adapter - N300 Wireless NIC (USB300WN2X2C) - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 1.6 cm x 2.2 cm x 0.8 cm
- 2.5 g
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 300 Gbps
- Frequency Band
- 2.4 GHz
- Processor
- Realtek Semiconductor RTL8192EU
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Black
- System Requirements
- Microsoft Windows Server 2003, Linux 2.6.x, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14, Linux 4.4.x - 4.11.x LTS versions only
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- 300 Gbps
- Frequency Band
- 2.4 GHz
- Status Indicators
- Link/activity
- WMM support
Aerial
- Antenna
- Internal
- Antenna Qty
- 4
Processor / Memory
- Processor
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA
- Black
- Software Included
- Drivers & Utilities
- OS Required
- 1.6 cm
- 2.2 cm
- 0.8 cm
- 2.5 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R | In Stock | £12.65 |
StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R USB WiFi Adapter - White | In Stock | £11.73 |
StarTech.com USB 2.0 AC600 Mini Dual Band Wireless-AC Network Adapter - 1T1R 802.11ac WiFi Adapter | In Stock | £27.34 |
StarTech.com WiFi 6E USB Adapter/Dongle | In Stock | £63.56 |
