Add high-speed Wireless-N connectivity to a desktop or laptop system through USB. The USB150WN1X1W USB Wireless Network Adapter lets you add high-speed Wireless-N connectivity to a desktop or laptop system through USB.
Using a 1T1R (1 Transmitter/1 Receiver) design over the 2.4GHz frequency, the USB WiFi adapter is capable of data transfer rates up to 150Mbps over an 802.11n network. The adapter uses a small form factor design that makes it conveniently portable and unobtrusive, when connected to a computer - it can even be left connected your laptop when in a carrying bag, without worry of damaging the adapter or the host port.
Backward compatible with 802.11b/g networks (11/54Mbps), this USB wireless adapter is a versatile wireless networking solution, offering support for security options such as WEP, WPA or WPA2, as well as wireless Quality of Service (QoS) support and quick device connection through Wireless Protected Setup (WPS).
- StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R USB WiFi Adapter - White USB Wireless Adapter - Wireless NIC (USB150WN1X1W) - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 1.5 cm x 1.9 cm x 0.7 cm
- 9 g
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 150 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- White
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Apple MacOS X 10.5 - 10.14, Linux 2.6.x - 3.5, Linux 4.4.x - 4.11.x LTS versions only
- 2-year warranty
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- 150 Mbps
- Frequency Band
- 2.4 GHz
- Full duplex mode, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), 1T1R MIMO technology
Aerial
- Antenna
- Internal
- Antenna Qty
- 1
- Encryption Algorithm
- AES, TKIP, WPA, WEP
- White
- Software Included
- Drivers & Utilities
- OS Required
- 1.5 cm
- 1.9 cm
- 0.7 cm
- 9 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90%
StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R | In Stock | £12.69 |
StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R USB WiFi Adapter - White | In Stock | £13.78 |
StarTech.com USB 2.0 300 Mbps Mini Wireless-N Network Adapter - 802.11n 2T2R WiFi Adapter | In Stock | £17.56 |
StarTech.com USB 2.0 AC600 Mini Dual Band Wireless-AC Network Adapter - 1T1R 802.11ac WiFi Adapter | In Stock | £31.08 |
StarTech.com USB Dual-Band Wi-Fi Adapter | In Stock | £22.95 |
